07-31-2009, 06:34 PM | #1 |
P/S idler arm swap?
I have a 66 short step I swapped the front cross member on from an 81 half ton. I need to find an idler arm that will work with the 81 center/drag link. What have you guys used? I did a search and came up empty. TIA!
07-31-2009, 06:42 PM | #2 |
Watch out for your cornhole !
Re: P/S idler arm swap?
I used the later model idler arm too. Just clamp it into place and drill the two holes.
07-31-2009, 07:32 PM | #3 |
So just eyeballing it get's it close enough??
07-31-2009, 08:27 PM | #4 |
I've done two trucks that way without any problems. Just square it forward to back and level the center link in relation to the crossmember. Use C clamps to secure it to the frame and drill the two holes.
08-01-2009, 11:12 PM | #5 |
60-66 Nut
Just use your original idler and drag link as a reference. Take some measurements and position the newer one in the same position and then do as Tx Firefighter said, clamp it to the frame and drill your holes.
08-02-2009, 12:16 AM | #6 |
HOW long until spring??
I just swapped a 71 crossmember and spindles under my 64, using all 71 tie rods and components including the 71 idler arm. And it is just like the boys have said before me , measure, clamp and drill away.
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
08-02-2009, 01:29 AM | #7 |
OK, thanks for the tips.
08-02-2009, 10:27 AM | #8 |
I noticed that if you bolt up the steering box first it give you the right angle on the idler arm. Before I knew about the REZ kit I just drilled some holes and bolted up the steering box with some spacers. After I used the rez kit I had to redrill my idler arm again as it angled back about 1/2". I welded a piece of 1/8" metal to the back of the first hole I drilled and filled the hole back up and then drilled a new hole. can't have oblong holes holding the idler arm.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
