Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-01-2009, 07:23 PM   #1
ozzie50
maybe a v-8 swap need some info
I have a 1991 s-10. I am really thinking about going with a 350 and going with a carb. My question is what can I use of my 4.3 liter. I would like to keep the 1 belt. And kept the accessories where they are. Can I do this? What year engine would I need? Any info would be great.
ozzie50 is offline   Reply With Quote
Old 08-01-2009, 11:15 PM   #2
BarryB
BarryB's Avatar
Re: maybe a v-8 swap need some info
Well if you have a 4.3 in your truck then your pretty much in luck everything will swap over to a V8. Heck if you wanted to, you can use your existing wire harness, diconnect all the TBI stuff. and get a91 TBI V8, swap it in, and it will plug up. you would however need to get the prom from the v8 computer. or just swap in the whole computer.
This is what I plan on doing with mine. Mine is a 2.8 TBI 5 spd. But I found a 4.3 5spd I gunna get to swap in. so I'll have a v8 TBI 5spd S10. And when I do it, I'm using all factory stuff, camaro manifolds. so when you pop the hood it will look like GM put it together.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 08-02-2009, 01:52 PM   #3
ozzie50
Is there a certain year of block and heads to look for to make sure I got all the correct bolt holes for the pulley set up?
Old 08-02-2009, 02:28 PM   #4
Low&Slow83
Low&Slow83's Avatar
pretty much all GEN1 small blocks have the same serpentine holes for the bracket you have. even the V-belt engines have the same holes.
1983 Chevrolet C10 - 1st car/ Daily Driver / Project
1995 Nissan 240SX - SOLD
Low&Slow83 is offline   Reply With Quote
Old 08-02-2009, 08:50 PM   #5
BarryB
BarryB's Avatar
Yeap what he said as long as the heads have accessory holes, the serpentine belt system will work. BUT you'll need to make sure you get the correct water pump. the serpentine ones spin back wards compared to the older water pumps.
Two rules in life.
Old 08-03-2009, 12:49 AM   #6
ozzie50
Will a/c parts be the same?
Old 08-06-2009, 03:22 PM   #7
BarryB
BarryB's Avatar
Yeap!
Two rules in life.
Old 08-06-2009, 09:24 PM   #8
Jonce
Jonce's Avatar
I think you should go with a LSx engine instead
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 09-01-2009, 07:45 PM   #9
chevyndn
make sure if you go tbi you use the right year of heads, cuz the four bolts in the middle are diiferent on older carb heads than on tbi, the older ones all angle, the 88-95 go stright up. you can use either heads if you woller out these four hole of the intake
chevyndn is offline   Reply With Quote
Old 09-03-2009, 11:27 AM   #10
Damien
Damien's Avatar
You can also get spacers that go under the bolts that correct the angle problem. Perfessional Products intakes come with them I think.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 09-03-2009, 06:50 PM   #11
The Big Green
I just did a V8 swap in my '91. Not a swap that the average guy would do, but at 600hp all engine, I guess it was worth all the hours.
Post pics when you do this swap.
The Big Green is offline   Reply With Quote
Old 09-05-2009, 07:13 PM   #12
5.7L JWL
Man that is a TRUE sleeper there. Maybe not so much after you crank it up, but just sitting there it is.
Jay
'98 C-1500 ECSB 5.7L Edelbrock shorty headers Ceramic, Stage 8 locking header bolts, Magnaflow S/S y-pipe w/converters, Magnaflow S/S
Cat-Back Exhaust (DI 2.5" / SO 3.5" w/ 4" Tip.) Synthetic Fluids throughout. Polished TB with Blade removed, ASP Pullies, Performance Distributors "Vortec Firepower" Ign. Kit, BlackBearPerformance Tuned PCM '84 Kawasaki KX-80 "Mint"
5.7L JWL is offline   Reply With Quote
Old 10-23-2009, 02:37 PM   #13
bigbadjohn84
ohhhh stop... now your just showing off. I love that little truck. want a HHR? lol
bigbadjohn84 is offline   Reply With Quote
Old 11-12-2009, 02:45 PM   #14
streetstar
streetstar's Avatar
Are you trying to build something wild and nasty (like a couple of the guys above described-- 600 hp - sheesh) or just a mild cruiser?
Have you thought about rebuilding the 4.3 ? It will do everything a mild V-8 will do. But rebuild costs may be a bit more than a 350, IDK. Unless you have a small block just sitting around ready to go, its tough to beat a strong running 4.3 in these small trucks
(that is of course unless you are planning to do something wild, like the 600 hp truck or that LS truck, which is very cool)
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 11-13-2009, 11:24 AM   #15
Damien
Damien's Avatar
[/QUOTE] Have you thought about rebuilding the 4.3 ? It will do everything a mild V-8 will do. But rebuild costs may be a bit more than a 350, IDK. Unless you have a small block just sitting around ready to go, its tough to beat a strong running 4.3 in these small trucks
(that is of course unless you are planning to do something wild, like the 600 hp truck or that LS truck, which is very cool)[/QUOTE]
Building a 4.3 will cost a little more then a 350. The cam and intakes are more expensive. You will save a little weight over an iron headed 350, but if you have A/C it probably doesn't matter. The packaging is going to be easier with the 4.3 though.
Old 11-30-2009, 09:30 PM   #16
towb3
If he is to order a new intake when he builds, they have intakes that can match up to what heads he is using instead of grinding up an intake.
towb3 is offline   Reply With Quote
