Old 08-03-2009, 12:30 AM   #1
jess66chevy
jess66chevy's Avatar
Flywheel vs. plexplate? DIFFERENCE???
Whats the difference between a flywheel and a flexplate?
jess66chevy is offline   Reply With Quote
Old 08-03-2009, 01:00 AM   #2
PrerunnerRob
PrerunnerRob's Avatar
Re: Flywheel vs. plexplate? DIFFERENCE???
A flywheel is used in with a manual transmission, a flexplate is used in an automatic.
PrerunnerRob is offline   Reply With Quote
Old 08-03-2009, 10:44 AM   #3
MacAttack
283 Drama Queen
MacAttack's Avatar
Flexplate:
Flywheel:
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 08-03-2009, 10:47 AM   #4
ol Curt
Junior Member
ol Curt's Avatar
Hmmmm....I guess that means I have to buy a flex plate in order to hook up the TH350 I am getting this Friday. Are they sized by engine, transmission or some other means?
Thanks!
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 08-03-2009, 05:35 PM   #5
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Should be sized by engine and starter location. Some engines are internally balanced and others externally balanced. Some starters bolt to the block and some bolt to the transmission, each requiring a different ring gear tooth count.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 08-03-2009, 06:13 PM   #6
jess66chevy
How do I know if I need an "external" or "internally" balanced flexplate?
Old 08-03-2009, 06:44 PM   #7
bigsnookmaster
bigsnookmaster's Avatar
If you have a small block 400,you need an external one. All other small blocks are internally balanced. I believe that 454's are also externally balanced as well.
bigsnookmaster is offline   Reply With Quote
Old 08-03-2009, 08:21 PM   #8
TheDark1
TheDark1's Avatar
I think BigSnook is right. Stroker 383's are external also. I don't know about the inline sixes though.
1997 Formula WS6
Old 08-03-2009, 08:30 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My first answer to the difference is about 45 pounds.
Seriously though, inline 6 engines in 230 and 250 size use the same unit as the normal internally balanced small block. 292 has larger bolts, so the holes are too large for small block use.
Easiest way is to go to any common parts store and tell them you want a Pioneer FRA100. That's the common flexplate that fits all small blocks but the 400.
Expect to pay about 35 dollars. Places like O Reilly keep them on the shelf in stock.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-15-2012, 12:15 PM   #10
hungarian1964
I installed a 168th tooth (14") on my 68C-10
250 Inline 6, backed with a TH350. That is the WRONG Flexplate, the starter shaft hits it, needs the 153th (12 3/4") Flex
hungarian1964 is offline   Reply With Quote
Old 06-15-2012, 01:40 PM   #11
Tx Firefighter
Starters and flexplates have to match. You had a mismatch between your starter which was intended for a 153 tooth plate and the 168 tooth flexplate. It's not that the 14 inch one was wrong, it just didn't match your combo. You can use either as long as you keep the differences in starter in mind when you choose.
Old 06-15-2012, 02:21 PM   #12
hungarian1964
That's great info, but when I go to the autoparts store, they only come up with one starter for my application , what should Zi order??
Old 06-16-2012, 06:19 PM   #13
bama63
bama63's Avatar
if your starter bolts to the block the diagonal bolt pattern starter head fits the 168 tooth flex plate and the straight across pattern fits the 153 tooth hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
