Old 08-03-2009, 05:25 AM   #1
S10Fan
Old Heap Driver
Rear window seal
OK guys, I'm calling on the forum's brain trust. I need a new rear window seal, I realize there's a difference between the seals for regular windows and a slider. Now I'm told there's a difference in slider seals depending on a factory or non factory window. How the heck do you tell the difference?
Thanks!
Bryan
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 08-04-2009, 01:18 AM   #2
texasfunk
texasfunk's Avatar
Re: Rear window seal
i think a factorylooked more like a fulll piece, i cant explain it without pics, but my 87 has a non factory i beleive, pay attention to the top, theres a littler strip of metal with no glass, on the others, they go all the way to the top
factory, window frame and glass go to the top
non-factory(i beleive), window doesnt curve or go all the way to the top, and has a strip up top
texasfunk is offline   Reply With Quote
Old 08-05-2009, 05:21 AM   #3
S10Fan
Old Heap Driver
I went back to an ebay seller I dealt with a couple years ago. Here's what he said................
"You can usually tell the factory sliders because their flange that fits in the rubber is about 3/8-1/2" thick. The aftermarket slider is made to the same thickness as the flat glass about 1/4". You can also look on your slider for a brand name. Some aftermarket companies would be CR Laurence, OWG, Prestige, Jackson Mfg."
Bryan
Old 08-06-2009, 09:04 PM   #4
1984 swb chevy
1984 swb chevy's Avatar
I have never had an issue with the rear rubber when changing out rear windows. I always remove the rear slider and install flat glass back in the same rubber.
2010 Tahoe
1984 C10
2005 Harley FLH
1941 Willys Pickup (will never get it done) not for sale
1984 swb chevy is offline   Reply With Quote
Old 01-01-2013, 05:44 PM   #5
GM-power
GM-power's Avatar
Sorry to dig up a old thread; did you figure out a gasket or use the stock one for your aftermarket slider? I picked a aftermarket one up without a gasket and am puzzled as to how to make it work.
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 01-01-2013, 05:52 PM   #6
LONGHAIR
As long as your original seal is not cracked or overly stiff, it will work......chances of that are slim, so I would start with a new one.
IIRC the only realy difference in the gaskets themselves is the some of them have a "locking strip" that fits into a groove in the rubber after it is all pulled it. I think that was a later year running change though. If yours doen't have it, don't worry about it. They are harder to deal with anyway.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-01-2013, 08:27 PM   #7
bigd65
bigd65's Avatar
I JUST changed mine from a slider to a flat glass and used the very same seal
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 01-02-2013, 10:15 AM   #8
ramz
ramz's Avatar
I just changed mine out from flat to slider and used the same original seal.
ramz is offline   Reply With Quote
