#101 |
Village Idiot....
Re: Hazel the older Sister....
One last picture before I put it to bed for a while.......
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
#102 |
Official Site Guitar Shredder
Looks great....Wheels Tires...? Specs on offsets...?
#103 |
20x8.5's 5.25"BS w/255-40-20's
22x9's 5.50"BS(75% confident) w/265-40-22's
#104 | |
Village Idiot....
You are 100% correct.........you know the numbers!
#105 |
Under Construction
keith, Truck is looking good!
if you dont mind me asking where did you get the dolly's from. I have seen some at harbor freight, but just curious, where you picked those up from, and are those the same dollies that are supporting the jackstands in previous pics. Thanks Heath
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 08-03-2009 at 09:57 PM. |
#106 |
Tot Roddin'
Lookin' good Keith!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#107 | |
Village Idiot....
I picked them up at a local swap meet and they are the same ones that are supporting the jack-stands.
#108 |
Under Construction
Thanks for the info bro...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#109 |
Village Idiot....
Here you go 67cheby, sorry it took so long...and the poor quality! I tried several angles, flash on, flash off and got the same.... I'll try again with a different camara
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold Last edited by n2billet; 08-07-2009 at 10:38 PM. |
#110 |
I've been trying to figure this one out w/o publicizing anything. Tonight, for some reason
![]() STELLA . . .......
#111 | |
Village Idiot....
#112 |
*NO REGRETS*
I think I too may have this can! Great name Scoti!
#113 |
Here's a pic for you 2WD guys, I saw this fancy rearend at the Carlisle show last weekend. It was on a 72 truck...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#114 |
On the fast track to nowhere..
I don't think we have a flat enough road to drive that on here
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#115 |
man that hurts my head thinking bout how that works, and how well it would work....?????
#116 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Looks like the shocks "lay down" when the bags "air up". I'm pretty sure that won't work.
#117 |
*NO REGRETS*
Looks like it'll work to me.
#118 | |
Tot Roddin'
Guy's (SCOTI/n2billet), I think Heath was able to pull the information you might need in relation to the KYB shocks. Check it out...
#119 |
well deserved ttt
bogey5 |
#120 |
hey n2billet,, can you help me out, new to the truck scene, what do you mean scuff and spray, and cover in laquer thinnner? gona do my truck soon and really like your methods, scotch brite brillo pads? or the green pads, and what kind of spray can paint u reccomend........ thanks any help is appreciated.....
68 C/10 short bed 77 C/20 silverado long bed 05 GMC Duramax Crew |
#121 | |
For color, we like to drive these things which means stuff will get chipped/scratched & we want to be able to do quick spot repairs. The frame/suspension are coated w/Krylon industrial semi-flat black (available @ places like Grainger & Fastenall). Easy to apply, dries fast, but is not bullet proof. If there's any hint of rust on your frame (none on this one), use a DA sander on the outer surfaces to remove as much as possible (all of it if possible). A large diameter wire wheel on a drill will help get stuff off the inside surfaces. Just wipe everything down w/thinner or degreaser prior to laying down your choice of color. Use 'lint free' towels too to keep things free of lint trash.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-25-2009 at 01:36 PM. |
#122 |
I'm just glad to be here!
SCOTI is right, that is a fool proof way to prep one if you are going to drive it and not make a trailer queen. For the paint, I have used Rustoleum Semi Flat Black that I got from Home Depot and was very pleased with the results. Same as the Krylon, tought but not completely bullet proof.
I hope the we get to see more of Hazel soon, I know he has other more important things on his plate right now.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#123 |
scoti,,,,thanks just what i was looking for, gona start on front end this weekend, will look for the paint here in so cal.... thank again......... Lou
#124 |
Village Idiot....
progress
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold Last edited by n2billet; 05-20-2010 at 04:29 PM. |
#125 |
Village Idiot....
Pictures of it together.....
