Old 08-04-2009, 07:50 PM   #1
70k52wd
Blaze-Air
70k52wd's Avatar
leaking brake lines
I put new disk brake hoses from Carquest on my truck. They keep leaking where they bolt to caliper. I replaced cooper gaskets, and still leak. Anybody else have this problem? They're 73 style. Square blocks.
70k52wd is offline   Reply With Quote
Old 08-04-2009, 08:02 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: leaking brake lines
I assume you have 2 copper gaskets per hose/block?
They have to be really tight when they are new gaskets being crushed for the first time.
Keith
Convert to disc brakes.
Old 08-04-2009, 08:33 PM   #3
70k52wd
Blaze-Air
70k52wd's Avatar
Yea, 2 gaskets ea time. These hoses never fit flat on the caliper to begin with. I had to gently persuade them to a flatter fit. It's just the passenger side.
I have some thicker gaskets, but I don't see that as a resolution. I cranked them hard. I'm always worried about stripping threads.
Old 08-04-2009, 09:07 PM   #4
lolife99
lolife99's Avatar
I have the steel line of the rubber hose pointing up. Is that the way you have them?
Any pics?
Keith
Old 08-04-2009, 10:11 PM   #5
70k52wd
Blaze-Air
70k52wd's Avatar
I don't have a close up enough pic. It runs forwards. If I remember, that was the only way it could route. I'll be crawling under it tomorrow. The Dr side is fine.
Old 08-04-2009, 10:45 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Are you running dropped spindles? You might have to tweak the line to help in clear the spindle casting.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-04-2009, 10:56 PM   #7
70k52wd
Blaze-Air
70k52wd's Avatar
Yes, I need to do some tweaking. They just never sat flat up from the start. I'll tug and cuss a bit till I get it. Should have gotten Napa hoses.
Old 08-05-2009, 08:35 AM   #8
70k52wd
Blaze-Air
70k52wd's Avatar
Here is a pic of the driver side hose. Not the best angle, but you can see the routing.
Old 08-05-2009, 05:11 PM   #9
lolife99
lolife99's Avatar
Looks fine at the caliper. Does it rub on the spindle/upper ball joint?
Keith
Old 08-05-2009, 05:26 PM   #10
cparman
sharp as a marble
I am with N2TRUX. I might snug the line up, and see where it hits, if it hits the upr bj nut or spindle. Then try and bend the line away from that and see you can then remove the line, and bolt it back up without having to make it fit. In other words have it bolt up in a relaxed way????
cparman is offline   Reply With Quote
Old 08-05-2009, 05:55 PM   #11
70k52wd
Blaze-Air
70k52wd's Avatar
I got up there today. Just for kicks I put a wrench on it. It tightened down a bit more. I'll bleed, see what happens. Nothing hits or rubs, but I agree with cparman that it should bolt in a more relaxed way.
