04-03-2003, 03:27 PM | #1 |
need help setting a 1406 carb
I am trying to set my 1406 edelbrock, but I am not understanding all of it. Can someone put it into words I can understand. One of my steps state "Adjust the IMS on one side to get the maximum possible RPM. Do not go rich beyond the maximum speed point." Can someone tell me what this means. I am setting my normal idle at 550 RPM.
04-03-2003, 03:49 PM | #2 |
it is saying idle mixture screws (IMS) these are the two screws on the lower part of the front of the carb.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
04-03-2003, 03:53 PM | #3 |
I know what the IMS is, this is the part I don't understand what it means "to get the maximum possible RPM. Do not go rich beyond the maximum speed point" I am trying to set it at 550 RPM on idle and 1500 on fast idle.
04-03-2003, 05:01 PM | #4 |
dont worry about idle speed when you're adjusting the IMS. adjust your IMS for maximum idle speed, and then adjust your idle speed screw. they are independent of each other.
04-03-2003, 05:15 PM | #5 |
I have that same carb and mine runs to rich. So my question is if i scrwed the two screws all the way in how many turns out should i start with from each screw.
04-03-2003, 07:31 PM | #6 |
I'm back with 2nd truck!
Start with 2 turns out. DO NOT TURN ALL THE WAY OUT!! What you want to do is turn in one side to where the engine starts to stumble then back out about 1/2 turn. This will get you very close. Then to the other side. Once you have this set readjust idle screw.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
04-03-2003, 09:48 PM | #7 | |
msl - is you carb running rich at idle or all the time? the idle mix screws are only gonna effect the mixture at idle.
04-03-2003, 10:12 PM | #8 |
It runs rich at a idle.
04-03-2003, 10:20 PM | #9 |
MSL, so does mine and has sence it was new. i dont care how i adjust it, it always runs rich on idle. i just get the highest possible idle with both sides equally adjusted out. the only thing i do is set the idle about 800-850, i think 550 is to low but thats my opinion.
2004 Silverado Crewcab (Dark Spiral Gray) |
04-03-2003, 10:39 PM | #10 |
Mine seems to only run with the screws pretty far out. and it runs rich it seems even when i adjusted them in it ran rich.
04-03-2003, 11:52 PM | #11 |
I've got the same carb. I even took my truck to a tune up shop to adjust the thing because I thought it was running rich. They told me they did the best they could but it still runs too rich and could not adjust it properly. I checked my plugs and they're REAL black. I don't know what to do. I may try your suggestions this weekend.
84 Chevy Stepside, 350, TH350, 268h Comp cam, Hooker headers, MSD Pro Billet, Edelbrock Performer manifold and 1604 carb, 40 Series Flowmasters dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi |
04-04-2003, 12:05 AM | #12 |
Take it to the limit
Step by step tuning for edelbrock 1406 follow this link
http://www.carbs.net/Weber/adjust.htm
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers 66 Cutlass 2dr hardtop currently undergoing frame off 55 chev 2dr hardtop awaiting attention 85 Chev silverado 1/2 ton loaded,daily driver(stolen) 80 chev silverado 1/2 ton farm truck 87 S-jimmy V-8,lowered ,Parting out 49 Chev 1/2 parting out parting numerous 73-80 chev trucks 01 Polaris edge X (highly modified) 58 NSU Prima scooter awaiting total restoration |
04-04-2003, 01:00 AM | #13 |
I took mine down to my local mechanic and they put it on the dyno to get it just right. I had the same frustrations as you did with running rich. Now it runs smooth all the way up to 8k rpm.
Just kidding
1980 1 ton utility 350 4bbl, manual, 4:56 rear work in progress, just ask my neighbors about the screaming coming from under it! |
04-04-2003, 04:06 AM | #14 |
Just kidding what about 8krpm. or both. so did you take it in what did they do if you did.roughly how much did youy pay.
04-04-2003, 04:54 AM | #15 |
Also im not sure if this happens to you guys but when i start my truck first time when engine is cold the choke comes on like it should revs up. but it will stay on until i kick it down. is this supposed to happen and sometimes like if i just go into the store and it isnt more than maybe 15 minutes the choke kicks on again and i have to kick it down.
04-04-2003, 02:56 PM | #16 |
The choke sounds like it's working. The choke gets cold and kicks in. Did you set your choke correctly? If not this can cause a lean rich condition.
04-04-2003, 05:41 PM | #17 |
I havent touched it yet. maybe i should adjust it and see what happens.
04-05-2003, 12:03 AM | #18 |
I was kidding about the 8k rpm. I believe it was around 75.00 for them to adjust it, may have been less. I messed with it for a while but could not get it exactly how I wanted it, so I let them do it. Probably the only time I let someone else work on my vehicle except for smog testing.
04-05-2003, 12:09 PM | #19 |
I just wanted to thank everyone who helped me with my carb problem. I have it now running a lot better. Just need to get a tach so I can set the rpm's right. Everyone here took the time to walk me thru this. I have asked questions on other boards and made to feel like the stupidest person in the world. I am not a mechanic and do not know much. I have been a cross country driver for almost 9 years now and never really had time to work on our vehicles. I am now staying at honme and have more time to fix these things up. Now, if I can only fix my brake problem, I think I will be done until it's trans repair time. Thanks again to all who helped guide me on this. Tommy Davis Little Rock,AR
