08-06-2009, 01:23 PM | #1 |
1970 C10
Booster to master cylinder?
I'm swapping from power drums to power discs and bought a master cylinder and proportioning valve off a 72 power disc truck, now i was told that the master cylinder will bolt onto the booster off of my 70 with power drums?
Also is there anything special i need to do for the swap? Thanks! |
08-06-2009, 01:53 PM | #2 |
Re: Booster to master cylinder?
Bench bleed the master really well to make sure you have no air bubbles left in it at all. Also, verify that the rod coming out of the booster is not too long or too short. If too long, it will slightly depress the piston in the master and cause your brakes to drag or lock up. If too short, your pedal will have to travel farther to engage the brakes. If the master and valve are used, make sure they are working well and not leaking. The valve sometimes gets clogged with gunk and rust.
08-10-2009, 09:55 AM | #3 | |
1970 C10
Also their is no seal that goes between the booster or master cylinder is there? Thanks! |
08-10-2009, 10:11 AM | #4 |
Active Member
You should be able to buy a brake cylinder bleeding kit at Napa or other parts stores. Google "bleeding the master cylinder" on the net and you can see how it's done. Lots of good info.
No gasket between master cylinder and booster. MC should be sealed and booster should be also. Probably better that there isn't one so a person can detect if there's a leak in the MC... |
08-10-2009, 11:02 AM | #5 | |
1970 C10
