Old 08-07-2009, 11:16 AM   #1
Jamokey
Need Opinions
I finally got my '67 on the road. The PO had lowered it with drop spindles in the front and leafs in the back with a c-notch. In the first couple hundred miles I found that the front tires were rubbing on the inner fender wells. To fix this I put smaller rubber on the front and the tires don't rub any more. Now though my headers rub the ground whenever I go over a hump in the road. The headers are the long hooker headers that go lower that the frame. In your opinions is it better to bag the front,change the headers or both?
Jamokey is offline   Reply With Quote
Old 08-07-2009, 11:55 AM   #2
cdowns
cdowns's Avatar
Re: Need Opinions
changing headers is alot cheaper easier and faster to do
Old 08-07-2009, 12:20 PM   #3
big_al_71
big_al_71's Avatar
Re: Need Opinions
I would also say change the headers as it would be alot cheaper but if money is no object then do both.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-07-2009, 02:20 PM   #4
mclairmo
Re: Need Opinions
Change the headers to mid length, block huggers or manifolds.
mclairmo is offline   Reply With Quote
Old 08-07-2009, 02:30 PM   #5
Jamokey
Re: Need Opinions
Thanks for the replies. I read a thread on here about a set of chrome headers that you can get off Ebay item#110419636740. Will these work, my truck has a late 60's 350ci with camel hump heads? I am pretty new to customizing so any help is appreciated.
