![]() Join Date: May 2009
pic's of power steering set up's
Does anyone have any pic's of power steering set up's for a 230 L6. My truck is a 65 GMC but Chevy's are the same so if you have some could you please post them? I used the search but came up empty. Thanks Vernski
HOW long until spring??
![]() Join Date: Mar 2009
Re: pic's of power steering set up's
I just found a bracket on E-bay but do not have it installed yet. I think there might be a missing piece and could use pictures also. I am glad somebody else is gonna stay with the I-6!! I looked all over for this bracket, finally found it off a 70 Camaro.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
Hey Vernski-- welcome from Southern Idaho
Hi Bubba thanks for the heads up and welcome. Well I bought a set of bracket and braces off ebay also and when I went to put them on nothing will fit. Well I got leperconned as in bend over buddy,[no offence if your Irish] but they were advertized as fitting a 230 L6. I hope you faired better than i did on ebay. Well I just needed some pic's to see if I'm headed in the right direction. I'm going to fab my own bracket if I can get an idea where they bolt up on a 230. That said I hope we can get some pic's to see how it should be. By the way where is Star at in Idaho I'm 8mi nw of CDA Thanks Vernski
great thread, now we need some pics. I'm starting this project on my 1966 C10, except i have a 305 sb. So I have to go junk yard hooping tomarrow to try and find my brackets. I have a 1986 power steering box and drag link. I'm hoping this will come close to fitting on my 1966 frame. I find find out more tomarrow.
1966 C10, SB305, bagged. 1955 VW Buggy, 2.0L 1978 Honda CB550 http://67-72chevytrucks.com/vboard/s...9&goto=newpost |
#6 | |
I have the correct bracket off a 250 I-6 camaro. It has been cut a little for header clearance. (No trouble to weld a piece back in) I found a E-Bay seller 's listing for the headers and sent a pm to him asking about the bracket and scored. I had been looking on the chevelle forums, nova -forums, H.A.M.B. the inliners etc (After looking here on the 60-66 boards first) Nothing in the local junk yards. Beginning to think I might have to fab my own. Planning on using a nova pump. I can send a pic tomorrow if you need.
60-66 Nut
Here are a couple of setups right here in the classifieds......I think they are both still available.....one for each of you
![]() http://www.67-72chevytrucks.com/vboa...d.php?t=355548
Hi Bubba yeah if you could post a pic of your bracket that would be great. I have mine drawn out but that's subject to change when or if I see something better thanks,---Vernski
#9 | |
Hey Bubba I found this link check it out.Vernski http://67-72chevytrucks.com/vboard/s....php?p=3430543
Just here to tinker
![]() Join Date: Jun 2008
Here is the power steering set-up on my '60:
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
???---Vernski Yeah I get it now Jolly Joker "Funny"
#13 | |
60-66 Nut
Those bolt on pulleys look like the ones for a small block with a short water pump. Which balancer do you guys have?
Hi John my balancer is a single pulley and has bolt holes I for either a pulley puller or I guess you could bolt another pulley to it. I have no idea what the norm is for these engines but it is a 230.---Vernski
#15 |
I already have a double pulley set up on both crank and water pump . Hoped to get to the pump today but worked on the tilt column instead.
#16 | ||
60-66 Nut
#17 |
[QUOTE=Captainfab;3456234]So does your balancer have the pulley built in or is it seperate?
It looks like it's one piece, so I assume you can bolt another pulley to it? Or do I have to get another one? Also where can I find either? Thanks---Vernski |
#18 |
60-66 Nut
[quote=Vernski;3456741]If it is the same crank pulley as a small block with a short water pump, I have a couple. I don't have anything for the water pump pulley though.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-10-2009 at 11:43 PM. |
#19 |
[quote=Captainfab;3458038]Thanks John that's one step closer will give you a call when I can pick one up, I hope it fits my luck has not been good lately on things fitting well. On another note did you get those instructions on the adapter plate formatted yet? if not is it possible to print them out somehow and I could pick them up? Just a thought thanks Cap.---Vern
#20 | |
60-66 Nut
[quote=Vernski;3458103]
#21 |
http://67-72chevytrucks.com/vboard/s....php?p=3431900
Here is another thread of pic's and stuff. Vernski |
