Old 08-07-2009, 11:06 PM   #1
dbmx66
successfully converted from lwb to swb!
pretty much what the title says, i chopped 14 inches out of the frame starting 1 inch after the first bed bolts holes. welded the frame back together after everything was ground square. then moved rear cross member up to the next set of hole, chopped 6 inches off the bak of the frame rails, re drilled bed bolts holes, bed is almost perfectly squared to frame.im happy it worked!
dbmx66 is offline   Reply With Quote
Old 08-07-2009, 11:09 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: successfully converted from lwb to swb!
i wanna see
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-07-2009, 11:21 PM   #3
dbmx66
Originally Posted by 3r!c84 View Post
i wanna see
will do. ill get some tomorrow when i go to the garage. the only problem is that i didn't take any pictures of the frame when it was under construction. i'll only be able to get some pictures of the finished project.
Old 08-07-2009, 11:40 PM   #4
3r!c84
Badass
3r!c84's Avatar
lol ok
-00 Saturn 5spd
1/4:13:90
Old 08-08-2009, 12:23 AM   #5
PRUNEDA
'87
PRUNEDA's Avatar
Sounds like you did a good job. Congrats
PRUNEDA is offline   Reply With Quote
Old 08-08-2009, 12:35 AM   #6
dbmx66
thanks man! im pretty happy the way it turned out, all the body lines match up perfectly
