Old 08-10-2009, 11:06 PM   #1
csb#356
Turbo 350 won't shift out of 1st
Ok, ive been having this problem for a while. I replaced the vacuum modulator then found out that the transfer case was in low. Put the t-case back in high but now it still will not shift. I tried shifting it manually but couldn't get it to but I don't know how high you have to rev before you try and shift. Someone told be that there is a little rod that goes into the transmission behind the modulator but when I replaced it I didn't see one. does this sound like a vacuum problem or a governor problem. Please help!
csb#356 is offline   Reply With Quote
Old 08-11-2009, 07:58 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Turbo 350 won't shift out of 1st
Usually if the trans won't shift out of first the vacuum modulator is not getting any vacuum from the engine. Make sure the line is connected at both ends. It is easy to knock it off and not realize you did it.
68 TT is offline   Reply With Quote
Old 08-11-2009, 08:26 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
as long as the modulator and the line is good, ive had them blow where you lose everything but first so it may be time for a trans
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-11-2009, 10:47 AM   #4
Chlsnk
Chlsnk's Avatar
I am having the exact same problem except mine is 2wd . Were do the vacume lines run to?
Chlsnk is offline   Reply With Quote
Old 08-11-2009, 01:41 PM   #5
csb#356
The vacuum lines run to the back of the transmission right above the pan. Passenger side. Well Im gonna check out the governor gear on mine because Im not ready to give up on this transmission yet.
