Old 08-11-2009, 11:58 PM   #1
AJLChase
AJLChase's Avatar
Frame bolts...pain in the you know what
O.k., So a few months ago I had my spine surgery...i've got about 4-5 weeks left until I have a CT scan to find out whether my spine is fused or not. Well, I've got a complete frame off project going on on the side. But, that's about as far as I can go as it seems that the bolts on the shocks, trac bar and trailing arms won't budge. I've got about a 1 1/4 long breaker bar that I can't do much more then use upper body strength and liquid wrench..and it's not doing me much good. What all do you use to tear your frame down to get it ready for sand blasting?
AJLChase is offline   Reply With Quote
Old 08-12-2009, 12:13 AM   #2
Mikey's68
Re: Frame bolts...pain in the you know what
"Wow" i wish you a speedy recovery. Some of those bolts can be a real bear to get off. Leverage is the key. Go big on your wrenches and use a cheater bar if you can. They will come off. I took my frame down to the bare minimum. If you are changing from a standard trann to an automatic i would take off that crossmember. They are rivited in, so you will have to drill them out. Also get primer or paint on it soon after sandblasting because it turn a pinkish color(rust) in a matter of days. Good luck with your build.
Mike
Mikey's68 is offline   Reply With Quote
Old 08-12-2009, 12:21 AM   #3
Rack Man
Torch.....no really....just applying heat will usually do the trick and you should be able to loosen them....and if not, use the torch to cut the bastards off.....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 08-12-2009, 12:52 AM   #4
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Can you get a air impact wrench on them? Thats what I would use.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 08-12-2009, 12:57 AM   #5
AJLChase
AJLChase's Avatar
I'd love to, but I honestly don't have an air compressor. I'd really like to save up some $$$ to get a large 60-80 gal one so I could use it later for painting = \
Old 08-12-2009, 02:09 AM   #6
tecky11
find an wlecgric 12v impact wrench. Mine gets 350ftlb of torque, that should bust the mothers off
and speedy recovery on the surgery
tecky11 is offline   Reply With Quote
Old 08-12-2009, 03:00 AM   #7
jbristo67
resident oilfield trash
jbristo67's Avatar
Go buy you some PB blaster penetrating oil. They will come right off
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 08-12-2009, 03:09 AM   #8
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Air impact wrench works best, and take your time don't over work yourself doing more than you should I had a Lumbar Fusion 5yrs ago & have 4 titanium screw's/rods what ever you want to call them in my back and trust me we can get a little carried away thinking nothing of it and over working our backs because we don't feel any pain at the time but later you will fill it.. I wish you a speedy recovery.....
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 08-12-2009, 08:46 AM   #9
big blue 72
Hey fellow broken back buddies. I have an electric impact that has come in very handy when you dont have an air compressor around.
Five spinal surgeries have slowed me down, but I keep on getting up, although i get up v-e-r-y- s-l-o-w-l-y.
Pace yourself, dont try and do too much. It will come back later to haunt you, then even the pain meds wont help.
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Unfinished Projects Club
Outdoor Sportsmens Club
big blue 72 is offline   Reply With Quote
Old 08-12-2009, 09:17 AM   #10
nsuengineer06
nsuengineer06's Avatar
I have found that a 4" side grinder with a cut-off wheel works wonders! When I began tearing my frame down I bought a handful of cut-off wheels and I've been back to the supply house multiple times to get more.. If you're gonna replace the bolts anyway and they're fighting ya, just clip em off.
1967 C10 LWB 454/TH400
1971 C10 SWB
1984 C30 LWB Dually 454/4 spd 4:10
2003 GMC Sierra 2500HD Crew 4x4 6.6L Duramax/Allison
nsuengineer06 is offline   Reply With Quote
Old 08-12-2009, 10:35 AM   #11
jaros44sr
jaros44sr's Avatar
If you're doing it on the cheap, a longer lever helps. I always keep a piece of pipe around to slide on my breaker bar. Be careful you can snap a socket-busted knuckles! All good answers above, but I prefer PB powerblaster and/or heat(propane torch)....black sockets are stronger
Bought my son an electric impact wrench for Christmas, and he told me he couldn't believe how strong it was
Wishing you a speedy return on the road to recovery
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-12-2009, 10:44 AM   #12
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
