#26 |
Re: domsan c10 custom
the gas tank for auto gas LPG the frame ready to paint Last edited by domsan; 08-14-2009 at 04:33 PM. |
#27 |
The first parts in color
#28 |
Never Ending Projects
Man that is looking great. You are sure working fast... much faster then I am.
![]() Keep up the great work and can't wait to see it finished. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#29 |
Really nice job so far
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#31 |
#32 |
the rear axle in paint and with airride
#33 |
the front axle in paint and with airride
and the first time again since a long time with the cab |
#34 |
looks great!
i really need to paint the rear end components on my truck.
Smoking Tires Since 1992 1969 c10 AKA SIN 1985 SSWB TRAZER (super short wheel base) |
#35 |
Looking at the flag, I would have guessed you were from SOUTH Germany!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#36 | |
Still Learning
Domsan, You are flying on this build. I can only imagine how many parts you can find for a 72 Chevy in Europe. Keep up the fine work! |
#37 | |||
i live in Germany, North Rhine-Westphalia therefore the flaage ! Quote:
parts here in germany learn you can forget Most parts we manufacture ourselves, or I do a buy in the Staates I'm always where I also share by private people in the usa can buy and I also agree then send germany but also over the last year in the United States a few people know |
#38 |
the bed
the steering the new brake |
#39 |
the lpg tank the door`s the doors would be in an acid bath and then removed once painted immersion |
#40 |
Your one damn skilled redneck. Excellent build. I like the fact you still do all this after halving to build most of your own sheetmetal. Most people would of sold it on ebay or CL by now. Can't wait to see it done. What kind of milage(Kmage) can you get out of that size tank. Thanks again for keeping some American steel on the road.
#41 | |
I have the truck on ebay germany yes bought! I immediately took the truck well as daily driver! The condition was I do not care, I like this work because it is then sometimes called to work I've had worse projekte my 34 chevy truck, which was worse to time, I have it only once because dan 72 left once the 72 chevy is finished I will be back in the 34 chevy go off times here are pictures of my 34 where I had picked him as you see has not much of this vehicle confessed, and had also bought a grille, but then I came to the idea of rebuilding the truck. than 50 'hot rod truck time to put about 3 years working in it on the lpg tank come 94 liters / 24 gal gas inside and has a range of 600 km / 372 miles |
#42 |
first paint the cab
#43 |
the new engine !
the engine is 350 chevy sb .030 over , edit crankshaft and pleule , trick flow cylinder head`s edelbrock camshaft and bridge and other changes . in the engine, I have a lot of work put inside the motor in the frame with gear the exhaust, a complete stainless steel plant with magna flow muffler |
#44 |
the cab on the frame |
#45 |
Still Learning
LOOKS GOOD! Man, you are moving fast!
#46 |
VA72C10
![]() Join Date: Mar 2008
Great work! Looking good. I'll be interested to see how low the rear sits with the bed on. I like the fact that with those cups you don't have to drill for airline in the frame. But I'm guessing the cups won't let you get nearly as low as without them...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#47 | |
Thank you!
for time is about 1 year working there in the truck We are in the end, if everything works out of the truck is ready next month Quote:
I did not want to make extreme frame work, the depth of the truck is ok for me. I am sure the truck would also lay on the ground, but unfortunately this makes here in germany the street with no |
#48 |
Preparation for paint |
#49 |
Damn, guess we'll have to wait for a color shot. Time for a commercial. Who makes that fuel tank? and what kind of carb do you use to run on both gas and LPG? Thanks. Jim.
#50 |
great looking trucks you have there, good job.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
