Old 08-15-2009, 11:17 AM   #1
bigarmzz
bigarmzz's Avatar
c-notch recommendations...bolt in or weld in?
which do you guys recommend? i'm wanting to go lower (yeah i know),..i want to lower the rear about an inch, and that will put my frame a bit too close to the rear housing..so....i want to c-notch the frame, and use one of those adjustable drop shackles to get 1" more of drop
my truck has a 1" rake that is driving my nuts...rear is up little more than an inch than the front
so i know i need a c-notch, just not sure if i should get one that welds in, or bolts in?
what have some of you guys done? which brands do you rec. or not recommend?
thinking seriously about the western chassis one from sport truck direct....dunno
thanks guys
-by the way, my current set up is:
wc 2.5" drop spindles-front
wc 2.5" coils -front
wc flip kit -rear
245/40-20's -front
295/40-20's rear
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 08-15-2009, 11:45 AM   #2
AirMale
AirMale's Avatar
Re: c-notch recommendations...bolt in or weld in?
western chassis c-notch welded
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 08-15-2009, 11:51 AM   #3
bigarmzz
bigarmzz's Avatar
man, that looks really really sharp airmale!!!!
Old 08-15-2009, 03:05 PM   #4
karl
karl's Avatar
Does a c-notch such as this cause any problems for how the bed sits on the frame?
karl is offline   Reply With Quote
Old 08-15-2009, 03:31 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
No, a "C" notch is just as pictured above. If you go larger with a "step" notch you will have to cut your bed.
Bigzz there is nothing wrong with a bolt in for normal use. If you plan to pull a trailer or haul loads, the addition of a weld in notch with a boxing plate is added peace of mind.
As AirMale demonstrated, you can always weld in a bolt in...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-15-2009, 06:16 PM   #6
bigarmzz
bigarmzz's Avatar
thanks Ken, thats kind of what i figured......it aint like i'm gonna haul a ton of gravel in this truck or nuttin
Old 08-15-2009, 06:20 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I went the opposite direction on mine. I started with a weld in, then converted to a bolt in. Of course there was a bit of motivation to my madness...
Articles-
"Refining Sierra"
