08-17-2009, 08:14 PM | #1 |
Cab Mount Hockey Pucks????
Is it true that you can use hockey pucks for cab mounts? if so how thick would the need to be. please help thanks
08-17-2009, 09:48 PM | #2 |
The Older Generation
Re: Cab Mount Hockey Pucks????
08-18-2009, 06:08 AM | #3 |
its all about the +6 inches
welcome to the forum from central Ohio!
a puck could be used... but it isn't the best idea... |
08-18-2009, 06:35 AM | #4 |
you could get a bonch of used boots and cut up the soles for mounts too// why bother original replacements are available cheaply to do the job correctly
welcome to the board. OAKDALE?? is that the long island one?
08-18-2009, 11:21 AM | #5 |
A Canadian body lift.
One puck is close to the stock height of the bushing. Adding multiple give you a body lift. Each puck is a inch of lift. Look at most body lifts... There longer bolts and rubber peices. So you want that 3" body lift then enough hockey pucks for 4 on each mount and longer hardware. |
08-18-2009, 12:10 PM | #6 | |
08-18-2009, 02:28 PM | #7 |
You can also buy one inch aluminum donuts for about $5 each online. I plan to buy them when i lift my body one inch.
Tags |
cab, hockey, mounts, puck, pucks |
