Old 08-18-2009, 11:09 AM   #1
CWT
Axle spline
I took the axles out of my 64 to have drilled 5 lug and the bearing surface was bad. So I got a 65 long bed step truck and I got the axles out of it. The axles out of my 64 are 30 spline and the axles out of the 65 are a courser spline(didnt count them last night). Could someone tell me whats what here?
CWT is offline   Reply With Quote
Old 08-18-2009, 05:14 PM   #2
SCOTI
SCOTI's Avatar
Re: Axle spline
'Early' spline count is 17; 'later' is 30. 30-spline axles should work by swapping axles & the accompanying spider-gears.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-18-2009, 05:21 PM   #3
CWT
Re: Axle spline
Thanks. So more than likely someone put a early rear in the 65 and a 65-66 rear in my 64? And thanks for the info. I was wondering if I could just swap the spiders out.
Old 08-18-2009, 05:56 PM   #4
SCOTI
SCOTI's Avatar
Re: Axle spline
They sell 5-lug axle swap kits for the early rears & include the spider-gears as part of the kit. Because of the gears, the early kits are a little more expensive.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-18-2009, 10:14 PM   #5
CWT
Re: Axle spline
Well I figured out the deal. My "64" is actually a 65. The man i got it and the long bed from told me the SWB was a 64 and the long was a 65. But he had them backwards. I just ran the vin and figured it out. I guess I will change spider gears since I have already got these 17 splines drilled.
Old 08-18-2009, 10:38 PM   #6
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: Axle spline
that's what I was going to say, They put the 17 spline in up to 64', Then changed it out in 65 with the 30.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
