Old 08-18-2009, 05:58 PM   #1
mainermikeyd
mainermikeyd's Avatar
frame questions
Can I put a k20 suspension(axles) an body on a k30 frame? Besides frame height an suspension what else would be different, I can get one from a local dismantler for $300 an wonder if it's worth it or not? I just had to weld in several replacement sections of my frame near the front spring perches for the rear leaf springs, bodyshop guys at work say if I get another 2 years out of my frame due to the repairs I will be lucky, I can post pics if it will help
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
Old 08-18-2009, 06:32 PM   #2
b454rat
Re: frame questions
Front axle will bolt in. The rear will need new perches. $300 is kinda steep for a frame inless it's dang near mint. The frames between the two is minor, the major being the 1 ton having taller frame rails. But take the spring mounts off you 3/4 frame and put them on the 1 ton frame, then everything will bolt up.
Kinda doing that to a crew cab I picked up. 2wd that I'm converting to 4wd. Got a set of spring hangers off a 1/2-3/4 for the rear, that way a 3/4 14ff will bolt up. Got DIY4X front spring hangers already on....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 08-18-2009, 08:20 PM   #3
mainermikeyd
Re: frame questions
well here are my 2 options the top pic is the k30 frame an the bottom frame is a k20 for the same price both needs sandblasting obviously but what are other members thoughts?? I have never sandblasted a frame on one of there, scale rust is one thing rot is another
GM Fanatic
Old 08-18-2009, 08:36 PM   #4
mainermikeyd
Re: frame questions
these are the pics of the pieces I cut out of my frame an replaced with 10 gauge steel
pic 1 drivers side frame front rear leaf spring perch
pic 2 passenger side mount for the gas tank
pic 3 pass side front rear leaf spring perch
GM Fanatic
Old 08-18-2009, 11:14 PM   #5
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: frame questions
I would go look at both of them and inspect them real good for rot and check for cracks especially around the power steering box. As for the sand blasting I would have to say it is well worth the money to have a business do it, after doing it myself once that is what i will do next time. That's just my 2 cents.
Tony
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
