Old 08-20-2009, 11:40 AM   #1
smoked68
smoked68's Avatar
Muncie M-21 front bearing ??
Does anyone know how to remove the front bearing from a M-21? I have been told I will have to remove all the guts to get it out. Any help? thanks
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 08-20-2009, 03:07 PM   #2
mikeoj
Re: Muncie M-21 front bearing ??
ttt
69 Lwb C-10 402/700R4
70 Lwb C-10 250/3pd
Wisc.
mikeoj is offline   Reply With Quote
Old 08-20-2009, 03:45 PM   #3
Wrenchbender Ret
I've never done a Muncie M-21 but I have pulled a lot of front brgs. on various trans. without tearing them down especially SM465's. Pull the retainer coller & the snap ring or nut that holds the brg. to the shaft. Wiggle the shaft & brg. out a little & put a brg. seperator behind the snap ring around the outside of the brg. Use a puller to pull the brg with the separator. If you dont have this equipment you can put some square tools behind the snap ring & tap the shaft back with a brass drift. Then pull the shaft out again & use a larger square slowly working the brg. off. Tap the new brg. on with the brass drift.
Wrenchbender Ret is offline   Reply With Quote
