Old 08-21-2009, 12:35 PM   #1
'87 Static Slam
'87 Static Slam's Avatar
Truck wont start
My truck is possesed by DEMONS!!
it basically starts when it wants to. my lights work, my stereo works, my air blows, but nothing happens when i turn the ignition. i can close the door and come back an hour later and it fires right up. it does this when its cold and hasnt been driven in a week, when its hot and i just stopped at the store, it does it for no apparent reason.
i think it may be that my alarm is not re-engaging the starter. All i do is close the door, set the alarm, and let it sit for a while. then i come back, de-acticate the alarm, get in and it starts right up.
i have taken it to a shop to be checked but it never does it while im there, the shop guys look at me like im crazy saying "it starts right up".
Could this indeed be my alarm? is there a way to disconnect the the starter dis-engage on my alarm?
thanks ya'll!
'87 Static Slam is offline   Reply With Quote
Old 08-21-2009, 03:03 PM   #2
Moostifer
a fool with no money
Moostifer's Avatar
Re: Truck wont start
sounds like you're on the right track with the alarm, But I don't know squat about them. when you say you went to a shop, are you talking about a repair shop or an audio/alarm shop? I would have the audio/alarm shop check ALL connections affiliated with alarm.
Now, for the "it sounds crazy, but..." it could be your connections at the battery. I have chased many a electrical gremlins back to bad connections at the battery. don't just look at them and wiggle the wires to see if they're tight. disconnect them, clean them, remove any rust with sand paper or file, and re-asemble them. If it fixes it, great. If not, well then you know without a doubt that, that is not what is causing it
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 08-22-2009, 02:19 AM   #3
TheSunDanceKid
TheSunDanceKid's Avatar
ive been doing alarms for a couple years profesionally look under your driver side dash should be a black box about the size of a pack of cigarettes look on the top of it should say "viper 550" or something like that find out what it is and ill tell you either how to bypass it or fix it
most alarms its controlled with a single 12volt relay which may have a bad connection or the relays going out usally not to comment but all it does is take your starter wire and interrupt it if you need more info PM me heres a paint i made real quick might help you the wire colors should be the same starter wire should be purple or yellow right under your steering colum should be noticeable the wires cut and butt connected off the factory
moostifer most alarms are usally not going to the battery its alot more work its easier to run it off the ignition harness then go all the way to the battery its not usally something thats done if it was done at an actuall shop it would of been "t-tapted" to the ignition harness
TheSunDanceKid is offline   Reply With Quote
Old 08-22-2009, 10:53 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
dollars to doughnuts its the alarm... ive disassembled many that have done this same thing
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-23-2009, 01:28 AM   #5
Orange77
Orange77's Avatar
ive got a viper alarm too and a few months ago was having the same problem. i swore it was the alarm messing up because i was having the same problems. turned out to be the starter heat soakin. swapped it out for a mini high torque hitachi and added 2 gauge wires with a few more grounds and it works way better. guarenteed to start everytime.
Orange77 is offline   Reply With Quote
Old 08-23-2009, 01:49 AM   #6
texasfunk
texasfunk's Avatar
mine has this exact same problem, i have no alarm, at first, it was a bad ground, and the next thing to check is starter, when the solenoid gets hot(header, manifoled, exhaust heat) it does this, i replaced my starter, put a heat shield, and havent had the problem anymore
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 08-23-2009, 01:56 AM   #7
Orange77
Orange77's Avatar
yeah i had a beast of a starter. the thing was HUGE and touchin the header no way a heat shield woulda fit but i plan on puttin one on my mini after i scrap up some more cash. i also heard that painting them with that VHT paint will lower the heat from them drastically since its ceramic paint.
Old 08-23-2009, 09:36 PM   #8
'87 Static Slam
mine does it when its cold too, so i dont think it's a heat issue.
went to start it today and nothing! Does everybody's do like mine does? meaning....do you still have working lights and stereo and air when this happens?
Thanks for the tips Sundance, i will get up under it sometime this week and have a look at the alarm wires.
