Old 08-22-2009, 09:02 AM   #1
82lowrider
Exclamation what transmission
Im new to the forum and new to these types of trucks wen my grandfather had the truck ha dskrewed up the transmission he had it in reverse nd pulled it with his farm tractor(i kno stupid) every gear works now except reverese. and my friend whos a mechanic said its not worth having the transmission rebuilt nd he said buy one. i dont kno what transsmission these trucks had can some body help me out nd tell me what transmission came in the 82 c-10 with a 5.0 motor
82 c-10 project 305 motor with 64,000 miles was my grandpas truck. needs new bed and doors and a rebuilt trannsmission. soon to have 3in cowl hood, 2inch drop, crager ss rims on low profile tires and new paint
82lowrider is offline   Reply With Quote
Old 08-22-2009, 10:17 AM   #2
3r!c84
Badass
3r!c84's Avatar
Re: what transmission
th350 3speed no overdrive
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-22-2009, 06:01 PM   #3
82lowrider
automatic?
Old 08-22-2009, 06:36 PM   #4
heavybullet
Yes auto.
heavybullet is offline   Reply With Quote
Old 08-22-2009, 07:09 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Being an 82 it's more than likely a th350C...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-22-2009, 07:19 PM   #6
3r!c84
Badass
3r!c84's Avatar
whats that C for?
-00 Saturn 5spd
1/4:13:90
Old 08-22-2009, 07:54 PM   #7
72 CustomCamper
huh ???
It means a turbo 350 with a lock up converter. GM's first try at a turbo trans overdrive...
Chuck
Old 08-22-2009, 08:04 PM   #8
3r!c84
Badass
3r!c84's Avatar
ohhh cool how do i know if i got a lock up converter ?
-00 Saturn 5spd
1/4:13:90
Old 08-22-2009, 10:32 PM   #9
72 CustomCamper
huh ???
The trans will have this electrical plug on the drivers side.
Old 08-22-2009, 10:41 PM   #10
3r!c84
Badass
3r!c84's Avatar
yep got that.
but u said it was GM's first try at a turbo trans overdrive..?
-00 Saturn 5spd
1/4:13:90
Old 08-22-2009, 10:49 PM   #11
72 CustomCamper
huh ???
I don't remember much, my buddy that has been a trans tech for years was telling us about them...
Old 08-22-2009, 10:59 PM   #12
joe231
joe231's Avatar
I have a 350C in my 80 short bed...it has a 4 connector plug in it though (later model).
It will not hurt the transmission to run it with out the lock up converter hooked up...
I did manage to get mine hooked up recently though.
search the faq section for 350C, there is lots of info about hooking them up.
from the factory there was a vacuum switch mounted on the fire-wall above and behind the brake booster that would disengage the converter when the gas pedal is mashed and the vacuum drops, and an extra set of contacts on the brake light switch that disengages the converter when you apply the brakes.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 08-23-2009, 09:41 AM   #13
D13
D13's Avatar
NOT an overdrive.
350C is a turbo 350 with a lock up converter. Basically at highway speeds the converter slips a little bit. By putting in a small hydraulic clutch the slip can be eliminated generating 3-5% less heat and improving gas mileage a little.
If it is a 350C than a regular 350 will bolt in place, just won't have a spot for the wire.
350's are cheap and cheap to rebuild too.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 08-23-2009, 11:42 AM   #14
3r!c84
Badass
3r!c84's Avatar
thank u
how do i know if mine is locking up?
-00 Saturn 5spd
1/4:13:90
Old 08-23-2009, 12:32 PM   #15
83burban
RPM will drop by 200-300 when cruising when it is locked
83burban is offline   Reply With Quote
Old 08-23-2009, 12:35 PM   #16
joe231
joe231's Avatar
drive at a moderate to low throttle, it will go first to second shift, then second to third then shortly after the shift to third you will feel another small "shift" as the converter locks...it is easy to miss unless you are at idle or just off idle.
CHEVY ONLY
Old 08-23-2009, 12:52 PM   #17
asphaltburner
asphaltburner's Avatar
Yo! I have a rebuild manual for the TH350/TH350C if ya need pics. The TH350 is a good tranny and was used extensively,...my '76 Camaro and my old '73 4x4 flatbed came with one as did most std-duty auto Chevys of the period.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 08-24-2009, 08:15 AM   #18
82lowrider
Thanks 4 the help
