Old 08-22-2009, 03:46 PM   #1
65ona90
65ona90's Avatar
'65 C10/'90 C3500 Build Up Thread
I figured i should start a build thread on this project incase anyone else is thinking about updating to a 88-98 type frame swap. I started with a solid 65 body, it was litterally sitting on an early 70's chevy frame with 6 x 6's and ratchet straps. So i figured since i didn't have the original running gear to start with, why not do a little updating. I started stripping a '90 C3500 extended cab long bed truck down to a frame with running gear (it was a running driving truck to begin with. Wire wheeled and painted the frame, then started the long and exhausting measuring process. The original cab mounts of the 65 fell directly center of the of the 90's frame rails. Blasted the holes in the frame and with some help of the body lift pucks mounted the cab. The wheel to wheel center measurement is exactly 1" different than original 65 measurment. The front clip was mocked up and now i am in the process of making mounts for the original BBC radiator. As far as suspension goes i just finished putting the belltech 8" rear flipkit on it, Kind of makes it look like its pulling a holeshot. I'll update some more pictures of steering connections, shifter linkages and the like in a little while.
65ona90 is offline   Reply With Quote
Old 08-22-2009, 04:36 PM   #2
MXmaniac
MXmaniac's Avatar
Re: '65 C10/'90 C3500 Build Up Thread
Sounds like you're moving right along. Got any pics?
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 08-23-2009, 12:04 AM   #3
65ona90
65ona90's Avatar
Sorry about that, this should give you an idea. I uploaded a photo of the truck i started with and then stripped. Unfortunatly i don't have any play by play pictures of the cab install. tomorrow i will grab some photos of the cab mounts on the frame now. It may take a few posts, internet is running at about half speed today.
Old 08-23-2009, 09:43 PM   #4
65ona90
65ona90's Avatar
Here is some pics of putting the cab and front clip on
Old 08-23-2009, 10:00 PM   #5
65ona90
65ona90's Avatar
Here is a few good comparo's of the rear lowering kit.
Old 08-23-2009, 10:52 PM   #6
65ona90
65ona90's Avatar
Heres a quick snapshot of the interior with the '90 bench seat sitting in there.
'65 C10 Body/'90 C3500 Driveline
'69 Chevy Nova SS (restored street/strip)
'66 Chevy II/Nova Gasser (work in progress)
'53 Chevy 210 Sled
'79 Chevy K5 Blazer (work horse)
'05 GMC Canyon
**It's worth putting money into as long as it wears a bowtie**
Old 08-23-2009, 10:55 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
pics are no bueno........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-24-2009, 12:15 PM   #8
65ona90
65ona90's Avatar
Sorry about the pics not loading, they should all work now. How to use the work computer.
'53 Chevy 210 Sled
'05 GMC Canyon
Old 08-25-2009, 12:15 PM   #9
65ona90
65ona90's Avatar
Soooo i set the bed on last night to see what kind of work its going to require. I think i have some work to do, what do you think? After measuring it out it looks like the bed needs to come down 4" in the front and almost 7" in the rear. I'm going to pull the bed wood out of it and see what kind of new cross members are going to need to be fabbed.
'53 Chevy 210 Sled
'05 GMC Canyon
Old 08-26-2009, 12:25 AM   #10
Captainfab
60-66 Nut
Yep you definitely have some work to do. Are you sure the back of the cab doesn't need to come up some more? Or is it an illusion since you have lowered only the rear?
Old 08-27-2009, 11:54 AM   #11
65ona90
65ona90's Avatar
It's an illusion, before the rear ws lowered the cab sat nice and level on the frame. With the cambo of the rear lowered and it being on a little bit of a hill, it looks way out of wack.
'53 Chevy 210 Sled
'05 GMC Canyon
