Old 08-24-2009, 12:21 PM   #1
71stub
71stub's Avatar
1 Ton Spindle Swap
I have a 1968 GMC 1 Ton 2WD and was wondering if I could swap newer 73-87 spindles onto my truck and get disc brakes and the larger wheel studs. Any help is greatly appreciated.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 10-06-2009, 04:36 AM   #2
JQ-72
JQ-72's Avatar
Re: 1 Ton Spindle Swap
Anyone??? I was wondering the same thing.
JQ
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 10-06-2009, 09:23 AM   #3
pumpkin
pumpkin's Avatar
I don't think there wpould be a problem. The front suspension on these trucks is basically the same from 67-87. The only differences could be the size of the ball joints and tie rod ends. I also seem to remember the frame being a bit different where the steering box mounts. You might be able to swap just the spindles, but it could turn into swapping everything. If you check with a parts store, and the tie rod ends and ball joints are the same part numbers then I would think you could just swap in the spindles.
pumpkin is offline   Reply With Quote
Old 10-06-2009, 09:37 AM   #4
2tons of fun
worse comes to worse you will have to swap everything, which is why i am skipping all the headach and just swapping everything.
2tons of fun is offline   Reply With Quote
Old 10-06-2009, 02:32 PM   #5
ERASER5
ERASER5's Avatar
I would bet that the entire cradle + tie rod/drag link will swap just like on the 1/2 tons.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
