08-24-2009, 07:52 PM | #1 |
box or plate for shortened frame
I just shortened my frame using the step method and was wondering if I should weld a plate to the backside or if I should box the frame in? Also what size metal for the plate or box? Thanks
08-24-2009, 08:17 PM | #2 |
Re: box or plate for shortened frame
either should work ... use 1/8 or 3/16
08-24-2009, 09:24 PM | #3 |
67GMC Slammed
dont buy the CPP frame stiffener, it is made just for that but it did not fit and then to try to get any help from those guys is imposible
08-24-2009, 09:27 PM | #4 |
I got some from ECE & they fit. I did this conversion & used 3/16" for fish plate & boxing.
08-24-2009, 09:48 PM | #5 |
3/16 and just plating is fine unless you want a fully boxed frame
1949 Five Window, 1973 Step Side, 2000 Z71 |
08-25-2009, 10:41 AM | #6 |
c10 Chop Artist
Its stronger to fish plate the directly over the joint than to box the frame. If the weld cracks the crack will run into the plate and stop instead of continuing all the way through. Here is a pic of a 66 frame i shortened to a SB wheelbase.
08-25-2009, 05:59 PM | #7 |
3/16th plate it is. thanks for the input.
08-25-2009, 07:59 PM | #8 |
Bodydropped71
Doing both would be fine to!
