Old 08-25-2009, 06:43 AM   #1
vtblazer
vtblazer's Avatar
HO52 Drums & Backing Plates
Ready to bolt on.
$95.00 shipped
vtblazer is offline   Reply With Quote
Old 08-26-2009, 05:42 AM   #2
vtblazer
vtblazer's Avatar
Re: HO52 Drums & Backing Plates
Or best offer...
Old 08-26-2009, 04:20 PM   #3
roger0080
I interested but:
1. are they for 9/16" or 1/2" wheel studs?
2. are they 11 x 2" drums? (I think that's what they should be)
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 08-26-2009, 05:36 PM   #4
vtblazer
vtblazer's Avatar
Originally Posted by roger0080 View Post
I interested but:
1. 9/16" (holes in drums measure 5/8")
2. Drums measure 12 1/4" in diameter, braking surface is 2"s.
Old 08-28-2009, 02:31 AM   #5
roger0080
Oh that's right they should be 12"x2", duh.
Is that 12-1/4" you state I.D. or O.D. ?
If it's not the I.D. can you measure the I.D. as accurately as you can?
I had a P.O. one time that had the drums worn way way (way!) past the the .060 to where they had to be replaced.
Thanks.
Old 08-28-2009, 08:00 AM   #6
vtblazer
vtblazer's Avatar
Closest I can measure with a tape measure tells me they're 12-5/16th I.D.
Old 08-28-2009, 12:03 PM   #7
roger0080
Let me compare that to a set I have out in the shed. Thanks.
Old 08-29-2009, 02:42 PM   #8
vtblazer
vtblazer's Avatar
Okay, let me know and I'll box em up asap if you want em.
Old 08-30-2009, 12:09 AM   #9
roger0080
I'm going to pass on them. Thanks.
Old 08-30-2009, 06:18 AM   #10
vtblazer
vtblazer's Avatar
Something wrong with them?
Are they over spec?
Old 08-30-2009, 01:36 PM   #11
roger0080
I think they are way over spec.
Brand new is 12" (thereabouts).
Legal wear to where you are not suppose to use them anymore I think is at .060", ie 12.060". I think the .060 is stamped on it someplace.
My old worn out pair measured 12-1/8" and weren't doing much for stopping (with worn shoes).
I'm not confident that brand shoes would fill up the gap enough to ensure safe braking for any length of time, but I could be wrong. It's a lot of work on those axles to experiment with the drums and hubs and see if you can make it go or not. I ditched my 12-1/8" worn ones in the past and found some used ones that had life in them to turn.
Old 08-30-2009, 01:55 PM   #12
vtblazer
vtblazer's Avatar
Fair enough, thanks for the info.
I got them from someone else by accident & never used em, guess they're headed for the metal dumpster.
Old 08-30-2009, 02:35 PM   #13
BCOWANWHEELS
If there still thick use them. Just measure the drum thickness with calipers. Remember when these trucks was made steel was cheap and they used alot of it. You can always have thicker pads on your shoes when you have them relinned too. These drums are very hard to find and forget about finding a set " in spec's. "
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-30-2009, 03:13 PM   #14
vtblazer
vtblazer's Avatar
Even better info.
Old 08-30-2009, 04:48 PM   #15
heyjoe
FWIW
My drum research for my '67 C20 w/HO52:
Standard issue brakes 11 5/32" X 2 1/2"
Optional Heavy Duty brakes 11 5/32" X 2 3/4"
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
Old 08-31-2009, 02:39 AM   #16
BCOWANWHEELS
Those drums look ok from what i see in the pic,s. Especially if your in a bind for drums. THE TRICK TO HARD TO FIND drums is when you have them turnned dont try to get them perfect, just turn em just enough to get the hi spots. the shoes will wear into the low spots. just something you have to do with hard to find drums.
Old 09-06-2009, 09:31 AM   #17
vtblazer
vtblazer's Avatar
Last bump, either they go to a board member who can use em or they go into the metal dumpster.
Tried several times over the last couple years to offer them up, tired of tripping over them.
