Old 08-25-2009, 09:31 PM   #1
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Name That Part/Item....Round 2
ok guys, i have been meaning to do this and finally got around to it,
does anyone know what these "F" looking thing on my cab are??
you can see where it was on the pass. side too...is it something the PO put on??
and i assume that the third pic is a factory bracket of sorts since its riveted, it it for the spare tire mount???
any help would be appreciated
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 08-25-2009, 09:35 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: Name That Part/Item....Round 2
I believe the 3rd one is an exhaust hanger. I've never seen shims like #1 before.
low'n slow is offline   Reply With Quote
Old 08-25-2009, 09:41 PM   #3
BAGNDRAGIT
BAGNDRAGIT's Avatar
ok an exhaust hanger would make sense..
shim for what, what bolted there??
Previous:
1969 Volkswagen Bug
Old 08-25-2009, 09:42 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
front inner fenders are bolted there
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-25-2009, 09:47 PM   #5
BAGNDRAGIT
BAGNDRAGIT's Avatar
ooooh ok. that makes more sense. Thanks CPNE and low'n slow.
now i know i can whack em off
Previous:
1969 Volkswagen Bug
Old 08-25-2009, 10:06 PM   #6
brn agn
brn agn's Avatar
CPNE is right. They are shims that go between the cab and the inner fenders. I just found the same ones when I pulled the inner fenders off my 1969.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 08-25-2009, 10:27 PM   #7
Jim_PA
Are the shims different sizes? Or are they one size fits all?
Jim_PA is offline   Reply With Quote
Old 08-26-2009, 12:20 AM   #8
Green Machine
Green Machine's Avatar
Our 68 had one of those "F" shims installed on one side only between the inner fender and cab as mentioned above. Did not reuse it because it is so ugly, just used some large diameter fender washers for shims. I guess the factory assy guys could get it shimmed faster with the handle on the shim given the location that it goes in.
The last one is a tailpipe hanger bracket, factory riveted to the frame. I just remove those since custom exhaust usually won't fit where the factory exhaust was. There should be one more exhaust hanger towards the front on the inside of the frame on the drivers side also, I think it uses 2 rivets
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
