![]() Join Date: Aug 2008
Wanted: 3.73 or 4.11 gear set
Anyone out there have a used set of 3.73 or 4.11 gears in good shape that will fit a factory 1971 chevy truck 12 bolt with 3.08 gears. I know i can purchas thru summit/jegs , but looking to save as much $$ as possible. Thanks Shawn
Re: Wanted: 3.73 or 4.11 gear set
What are you looking to spend? I ask because I have a set of NOS 3.73 gears still in the GM box - never had gear dope on them.
PM me if interested as I don't check the parts board that often and may not see your reply. Last edited by Shane; 08-26-2009 at 09:49 PM. |
You will need a spacer or a "thick" ring gear set. Your diff is a "series 3" which came with gear ratios up to 3.42:1. Ratio's from 3.73 and up were installed in a "series 4" housing. I have a good used set of 3.73s and a spacer (made by Mr. Gasket). Let me know if you are interested. /Al
LET'S GO RACIN'
![]() Join Date: Oct 2007
I also have a 3:73 gear set, it has some slight wear, but in real good shape. 65.00 plus shipping.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY ![]() Rip El Jay RIP BOBBO'S MOM |
Daren, what would shipping cost for 75142. Do you have pictures? Shawn
LET'S GO RACIN'
Will check on shipping. Yes i have some pics, will get them up.
LET'S GO RACIN'
77.41 with shipping. Here is a pic. "
Daren, will they work in my diff. case or will I need a spacer like Al said above?
LET'S GO RACIN'
Probably, but not for sure. I actually bought the gear from a member on the board.
Well I need to be for sure, i dont want to buy something that will not fit.
Al, you seem to know exactly what will work in my diff. case. What would you let the gear set and spacer go for and what would it cost to ship to 75142?
71 burb told you "square"....you need a spacer, or a thick ring to run a 3.73 or 4.10 on a 3 series carrier. The break on the carrier is 2.76?- 3.42 on a 3 series carrier. 4 series goes (factory) 3.73/4.10/4.56, ect. Not to try to step on toes, but personally, I would run a thick ring (3 series 3.73 or 4.10), or opt for a 4 series Eaton posi + gears. Best of luck,crazyAL
http://community.webshots.com/user/hotrodhorn |
Thanks 69 Longhorn. Do you know how to tell the difference between a 3 / 4 series eaton posi. I bought a carrier, it has 30060 cast # but I haven't found any info online re how to tell one from the other? Sorry, did not intend to hi jack your thread! /Al
