Old 08-27-2009, 01:23 PM   #1
Zeke
Active Member
axle length question
I ususally hang out on the 67-72 board but I have a question about axle lengths. I plan on putting a 12 bolt from an 81 GMC into my 69 and want to keep the 6 lug pattern. I noticed that 2wd axles are 1/32 longer 31-5/16 vs 31-9/32 for 4wd 6 lug. Will this make a difference? and are the axle housings different between 1/2 2wd and 4wd?
I have the pads to weld on the axle housing but not sure about the insides. Just want to make sure I am not dropping $$ into something that won't work.
Thanks for any info.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 08-27-2009, 01:31 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: axle length question
As long as the spline count is the same, I can't see where .03125" is going to matter.
And, you may have just been using the same type of stretchable tape measure that I used the other night!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-27-2009, 01:46 PM   #3
nlped
nlped's Avatar
^^^ I 2nd that!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-27-2009, 02:13 PM   #4
Zeke
Active Member
Thanks. Didn't think it would make a difference but when I went to order they showed different lengths.
I can relate to the stretchable tape, I have issue whether I am looking at it upside down or sideways
1969 C10 350 3spd
Old 08-27-2009, 04:37 PM   #5
Jonboy
Slots go on anything!
12 bolt 4WD axles will interchange with the 2WD ones. Just grab the drums, too.
Jonboy is offline   Reply With Quote
