08-28-2009, 08:29 AM | #252 |
Re: Intro from an old Assembly Plant guy
Yes - V6 (...we have a long and glorious tradition in my family of driving 6 cylinder pickups); factory tach, manual trans with cruise. It's quite a mixed bag....
I recall that I had to retrofit the cruise and the tach. The story was something like: they were available options with the manual trans but got stop ordered. When the stop order was lifted, engineering re-released the cruise and tach for the three-on-the-tree manuals but *forgot* about the floor shifted manual. As a result, I knew all the parts were available and would work but the system wouldn't allow me to order the truck that way. I got the parts after the fact and installed them myself. 22 years later they're still working! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-28-2009, 01:31 PM | #253 |
i like the emblem in the steering wheel
08-31-2009, 08:24 AM | #254 |
LOL! I do too; When I pulled the horn button apart to clean it the "bowtie" got messed up. I wanted a little custom touch to replace it and those Flowmaster stickers were exactly the right size (and the right colors!).
K
09-04-2009, 07:11 AM | #255 |
I didn't want you guys to think I was slackin'; I've been working on putting the new floor covering in.
Here's the dead stuff, coming out: ...and here's the new stuff going in. There was quite a bit of extra material on either side, and fore/aft, so I elected to position it based on the seat "humps" in the floor (and the seat attachments) and then trim the front portion to fit. This was quite a bit thicker/heavier than the original mat, which I think is going to be good for durability but it makes it a little hard to work with (unless you can get it warm and to soften up). I left it loose for a couple days, so that it could conform to the floor from the heat inside the cab (from sitting in the sun).
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2018 at 10:50 AM. |
09-04-2009, 07:12 AM | #256 |
And now I'm in the process of nailing it down. Here it is with the old sill plates; I will install the new sill plates and door weatherstrip after I repaint the door openings. I also have a new shift boot coming (the one I purchased several months ago was deemed "too big"...).
I don't like being able to see that red "skunk stripe" or red across the top of the toe pan above the black mat; I'm going to hit that with a little semi gloss black to hide it. It will also get covered up a bit by the heater discharge vent (not installed in this photo). K
09-04-2009, 08:19 AM | #257 |
Looks good Keith. Man it's almost a brand new truck now. You are doing wonders to it's self esteem.
09-04-2009, 10:06 AM | #258 |
ya she does look brand new! nice progress Keith!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-04-2009, 10:09 AM | #259 |
Looks good Keith!
Maybe you can answer a question I have. What exactly are the removable plugs in the sheet metal structure behind the cab corner there for? Is it a clean out? Are you supposed to pull the plug and clean the corner out from time to time? On our '66 there is a very similar plug in the front of the rocker panel, that if missing allows the rocker to fill up with dirt and rocks. Seems like a strange design
CHEVY ONLY |
09-04-2009, 10:26 AM | #260 |
a fool with no money
floor mat looks great!
btw... it's hard to drive without letting your feet touch the new mat!
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
09-04-2009, 11:55 AM | #261 |
Wonder what he is going to do with the engine
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die." |
09-04-2009, 01:42 PM | #262 | |
Nothin. Seems to run good...
I have wondered that myself: if it is a "sealed corner" then why do they rust out? Similarly why wouldn't they (ie, "we") have put a drain hole in there, so that you could flush them out? I seriously debated drilling a hole in mine before I put it all together, so that I could rinse the corners out during the winter. In the end, I decided to leave it the way the factory made it, figuring I replaced the corners once - I could do it again if I had to...
09-04-2009, 02:14 PM | #263 |
makes sense, thanks!
CHEVY ONLY |
09-05-2009, 09:11 AM | #265 |
I prefer the vinyl (notice that's how I ordered it originally).
K
09-08-2009, 12:21 PM | #266 |
Had an opportunity to get outside and do a few things this (long) weekend -
Got the door opening painted on the RH side, and the new weatherstrip/door sill molding installed:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2018 at 10:51 AM. |
09-08-2009, 12:22 PM | #267 |
- also got the new shift boot installed:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 02-19-2018 at 10:52 AM. |
09-08-2009, 12:23 PM | #268 |
...and I also made a little plate to cover the hole in the RH splash apron. I cut this out of an old piece of stainless steel I had laying around and painted it black.
K
09-08-2009, 01:01 PM | #270 |
...you'll be waiting for a while, too...
(LOL)!
09-08-2009, 01:08 PM | #271 |
Looks awesome Keith. That shifter really pops against the black floor. Nice work.
09-08-2009, 11:11 PM | #272 | |
Nice work!!
CHEVY ONLY |
09-09-2009, 09:01 AM | #273 |
What's the hole for in the door sill?
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
09-09-2009, 09:11 AM | #274 |
Dealer rustproofing, I believe. They are located all the way around the door frame. I have to get one of those little black "cap plugs" to close the hole.
K
09-10-2009, 07:50 AM | #275 |
I wasn't going to do anything with the shift ball....it cleaned up pretty well and was probably fine for a daily driver. But - I had a $40 credit with ClassicParts that I needed to use so I thought I would see what I could do here.
Now, you might suspect that the shift ball for this "odd ball" was probably not available, and you'd be right. However, if you were me, you'd figure that the manual transfer case shift ball was probably identical and would work in this application. So, I ordered one up: Pretty much exactly the same! After about 30 seconds of work, you can pop the indicator out of the old knob and slip it into the new knob and VIOLA!: new shift ball!
