08-31-2009, 01:29 AM | #1 |
fan clutch?
Are fan clutches the same for a big block versus small block trucks and how can I tell if mine is bad?
08-31-2009, 01:54 AM | #2 |
Re: fan clutch?
dont know the dirrernce between the clutches, but if it is bad the fan will still spin even after motor is off
08-31-2009, 09:45 AM | #3 |
20' Daredevil (Ret)
Re: fan clutch?
When you rotate the fan by hand, there should be some resistance -- it should feel like it's mired in molasses.
Typically on startup, the fan will be engaged for a few seconds, maybe for several seconds, and you will hear the roar of it moving lots of air -- then it should 'release' and the roar goes away. Some of the more aggressive fans can be heard engaging/disengaging as you drive, depending on cooling needs of the engine. If it never releases, or never engages, it's bad. Oh, check for a wobbly shaft too. Some clutches are a two-piece 'clamshell' design that can be unbolted -- mine is one of those. The temperature-sensitive silicon fluid inside can go bad or become depleted, but it can be replaced. The only source I know of is from Toyota dealers -- it comes in a pricey little vial. Mine went bad many years ago and I cleaned it out and put in fresh fluid -- it's been working perfectly ever since.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-31-2009, 01:18 PM | #4 |
Re: fan clutch?
The fan should stop turning when the engine stops. If the fan continues to spin then the fan clutch is bad.
And I believe the small block and big block clutces are different. Rob |
08-31-2009, 01:45 PM | #5 |
Re: fan clutch?
I bought a heavy duty clutch from Advance, as soon as I start driving, it stays engaged for 10-15 seconds. I've been thinking of downgrading to a non-heavy duty clutch to see if it doesn't make as much noise, but I'm not convinced it's worth messing with.
08-31-2009, 03:07 PM | #6 |
more ideas than money
Re: fan clutch?
The part numbers on NAPA's website show different fan clutches. Probably just heavy duty vs. light duty
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
