Old 08-31-2009, 08:34 PM   #1
abilityonline
68 C50 thermostat
I replaced the stock c50 radiator with a new F350 radiator (Chevy purists everywhere are screaming, I know)
I ran it for about 2 hours and it seemed fine, my problem is the temp gauge has never been hooked up. I don't know if it has a thermostat or not.
Question 1 where did these models run the thermostat? (Block, Hose, Radiator?)
Question 2 Also, with the F350 radiator modification, what type of setup would ya'll recommend?
abilityonline is offline   Reply With Quote
Old 08-31-2009, 08:56 PM   #2
mr48chev
mr48chev's Avatar
Re: 68 C50 thermostat
I'd run what ever thermostat that the factory recommended. Just make sure it is a high quality one. This is one place saving a couple of bucks isn't a good idea.
I think the sending unit is/was in the left head same as the pickups but I haven't worked on one of the bigger trucks in 25 years. I would rather have a good mechanical gauge than the electrical one on that truck.
Old 08-31-2009, 09:00 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it has a chevy inline or gas V8 engine, then it is in the thermostat housing at the end of the upper rad hose (engine end) and looks something like this;
(generic photo)
As far as your ford rad goes, it doesn't matter as long as it is secure, and is up to the task of cooling your engine.
I would recomend an aftermarket engine temp guage though, even if your stock one worked, it would still be a good idea if you work this truck.
Old 09-01-2009, 06:52 PM   #4
abilityonline
Thermostat was in there. Seems to be working. However my Temp guage isn't working. I believe originally the wiring ran to the rad cap. Can anyone confirm this?
Due to the modification of the F350 rad, can anyone suggest how to use the temp guage? I'd like to know what the engine temp is when fully warmed and under a load. (as well as it's just nice to always know)
Old 09-02-2009, 08:42 PM   #5
abilityonline
any info on ideas to get the temp gauge working?
Old 09-03-2009, 10:29 PM   #6
Longhorn Man
there shouldn't be anything wired to the cap.
While I have never worked on the old C/40 or bigger trucks, i would thing the coolant sensor would be in the head like on smaller cars/trucks of the day
