Old 09-03-2009, 02:49 AM   #1
SERKETSICCS1NINE
SERKETSICCS1NINE's Avatar
1961 question???
Can I fit a 700r4 in my 61 apache. I was told that it might not fit because of the frame design. It currently has a 4spd manual (1st gear is granny) and i want to convert it to a 700r4.
SERKETSICCS1NINE is offline   Reply With Quote
Old 09-03-2009, 08:26 AM   #2
61TWUK
61TWUK's Avatar
Re: 1961 question???
You will have to put in a different crossmember... but it will fit...
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 09-03-2009, 03:24 PM   #3
SERKETSICCS1NINE
Thanks for the info. Your the only person that has a 61 thats been able to answer that.
Old 09-04-2009, 12:18 AM   #4
Captainfab
60-66 Nut
You will have to remove the bellhousing crossmember. You may have to fabricate your own crossmember for the rear of the 700R4. It will only be a little over a foot long. since it will be right in front of the 'hoop' in the center of the X-member. 72bigred is putting a 700R4 in the '60 he is building for his wife is how I know.
Old 09-04-2009, 01:15 AM   #5
slepysal
slepysal's Avatar
ahh the lovley world of 60 to 62's here check this link out
http://www.persh.org/pickup/UnderThe...tm#Crossmember
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
