Old 09-03-2009, 06:08 PM   #26
68laydout
Junior Member
68laydout's Avatar
Re: All most on the ground! PB Style
Originally Posted by bigbadjohn84 View Post
are you serious? bolt on body drop? what is that like a complete custom frame??? I know there are some companies out there making complete frames to accomplish that.
You can easily get 1" body drop on these trucks by dropping the body mounts an inch. I should'nt say easy, because those body mounts are a major pita to get off because of the rivets holding them on. Not to mention the other stuff that gets affected by body dropping an inch. The only thing I see bolt on about it is new body mounts that actually bolt on. I assume the bed will have some bolt on mounts too? Interested to see what he comes up with for a true bolt on. It wont be more than 1" though, unless you want to raise the floor.
68laydout is offline   Reply With Quote
Old 09-04-2009, 11:13 AM   #27
C10Sim
C10Sim's Avatar
It was just a joke but from what i've read your explaination seems true.
1968 Chevy Pickup
http://67-72chevytrucks.com/vboard/s...d.php?t=321717
1959 Chevy Apache 3100 SWB Big Window
http://67-72chevytrucks.com/vboard/s...d.php?t=597069
C10Sim is offline   Reply With Quote
Old 09-04-2009, 03:50 PM   #28
royo
royo's Avatar
Originally Posted by royo View Post
thats cool i was just wondering what else goes with the wishbone do you have pics of that
ttt
nickle and dime
royo is offline   Reply With Quote
Old 09-04-2009, 05:50 PM   #29
68laydout
Junior Member
68laydout's Avatar
lmao, I thought I read a post that PB was talking about it. I read back through this post and looks like I took it hook, line, and sinker. Guess I need to lay off the crack pipe. That's some funny ****.
Old 09-04-2009, 06:06 PM   #30
GVizzle
GVizzle's Avatar
BOLT ON BODYDROPS NO JOKE.
Nate at Porterbuilt is gonna lay it out on in this thread in the near future.
http://www.67-72chevytrucks.com/vboa...d.php?t=358687
GVizzle is offline   Reply With Quote
Old 09-04-2009, 06:35 PM   #31
N2TRUX
Happy to be here
N2TRUX's Avatar
And that build ain't no joke either...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-04-2009, 06:39 PM   #32
68laydout
Junior Member
68laydout's Avatar
I knew I read that somewhere. I was starting to think I dreamed it up or something. Yes, I dream about this crap.
Here is PB's post on this from the other thread...
"This truck will see the installation of a couple more of our new products we haven't released yet. We will be finalizing our hood hinges, and the bolt-on body drop. I don't want to spill all the beans on the body drop kit... Obvious items will be the new bolt-on cab mounts that replace the steel units riveted to the chassis. The other main part of the kit... you'll have to wait for!"
Old 09-05-2009, 09:50 AM   #33
royo
royo's Avatar
do you any pics of what your going to use for the rest of the rear suspension
nickle and dime
Old 09-05-2009, 11:54 AM   #34
C10Sim
C10Sim's Avatar
Well I can see Nate coming up with a such kit and I had not read this thread but its looking cool!
Well I guess that some good PB crack!
I dont have any pic's for the rear because me and Nate are still working on brackets and design. As I get parts in (hopefully soon), I will post them up.
1968 Chevy Pickup
Old 09-05-2009, 01:40 PM   #35
C10Sim
C10Sim's Avatar
I finsihed installing the sway bar. I had to cut 1/4'' plate in order to fill some holes under the frame and weld them in to have a proper installation. Welding Overhead Sucks!
I also installed the steering joints and I didnt use all the parts but Im waiting on a response from Nate to see if this is proper or do I need to use DD joint and shaft heim joint aswell.
I think Im going to start on installing my brake pedal assembly. Im little iffy about it just because of the space that is left between from the trans to assembly is real tight and might require major exaust modifacation. We'll See!
1968 Chevy Pickup
Old 09-05-2009, 01:59 PM   #36
royo
royo's Avatar
MY steering wanted to bind up with 2 joints so i had to do 3
nickle and dime
Old 09-05-2009, 04:12 PM   #37
lowdownstar
big guy
lowdownstar's Avatar
Hey C10 Why did you have to weld up some holes? Did you use one of the stock holes and drill for the other? I didn't like how close the sway bar was to my bags and A-arms so i went and put longer bolts in with a spacer (on my end links) to bring the sway bar up higher. Thanks for the pic's it's been a big help for me. Yours is coming out great nice work!
Thanks again Ray
lowdownstar is offline   Reply With Quote
Old 09-05-2009, 06:35 PM   #38
C10Sim
C10Sim's Avatar
Thanks again Ray
There was one hole on each side that was falling in the middle of the hold bracket hole, so I filled it in aswell as some oval holes that were close by. Then I marked the hole locations and drilled.
1968 Chevy Pickup
Old 09-06-2009, 10:56 AM   #39
C10Sim
C10Sim's Avatar
I got the carry bearing crossmember and it was a b****, but some how it always works out. I also semi installed the hydro booster on to the frame mounted brake assembly and it's not going to work.
I might be able to install an indash brake assembly but im afraid the hydro booster is going to be loud inside the cab.
1968 Chevy Pickup
Old 09-06-2009, 12:21 PM   #40
Tagg33
Tagg33's Avatar
I have a hydro boost unit here too. Before I bought it I had plans to move the brakes under the dash. A neighbor of mine pointed out how uncomfortable it would be if one of the hydro lines ever broke or leaked in the cab. Hot ps fluid spraying all over your legs didn't sound good to me. But even if that wasn't a worry I didn't like the idea of routing the ps lines and the brake lines into the cab, just too much stuff. For now I'm still running my vacuum booster but I will eventually put the hydro on the firewall. Here is the advice I got from Hydratech, "I fully understand the shaved firewall look, though our direct bolt in systems for the '73-'87 GM C/K series is damned good looking (and would actually compliment your high tech looking engine compartment)." Their in favor of use showing off the goods they sell. And since I can't shave the steering column off the firewall I've made piece with keeping the brakes there too.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 09-07-2009, 12:20 AM   #41
VA72C10
VA72C10
VA72C10's Avatar
Looking good. Subscribed!
Old 09-07-2009, 03:44 PM   #42
C10Sim
C10Sim's Avatar
I dont think it would look bad but I think it's to close to the engine and then it looks really long.
1968 Chevy Pickup
Old 09-07-2009, 03:49 PM   #43
C10Sim
C10Sim's Avatar
Thanks for the compliments that everyone gives. It gives me some motivation to complete the project.
1968 Chevy Pickup
Old 09-07-2009, 05:58 PM   #44
royo
royo's Avatar
What else are you going to use with the rear wishbone??
nickle and dime
Old 09-07-2009, 07:03 PM   #45
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
I think the hydro booster brake setup looks clean there.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 09-07-2009, 08:25 PM   #46
C10Sim
C10Sim's Avatar
Im going to run inner lower link bars that attach right to the lower part of the dif bracket and inner frame rails. Im just waiting for Nate to send me some parts to complete set up.
1968 Chevy Pickup
Old 09-07-2009, 08:51 PM   #47
63 extreme low
63 extreme low's Avatar
awesome truck. Did you make the rear notch or is it porterbuilt?
63 extreme low is offline   Reply With Quote
Old 09-07-2009, 09:59 PM   #48
C10Sim
C10Sim's Avatar
That's a PB weld in notch.
1968 Chevy Pickup
Old 09-07-2009, 10:36 PM   #49
jlaird
jlaird's Avatar
This is looking great. What was the problem with the Nates Carrier bearing crossmember? Just go in hard?? I'm thinking about getting one.
jlaird is offline   Reply With Quote
Old 09-07-2009, 10:46 PM   #50
71'tahoe
71'tahoe's Avatar
Cool Project..
71'tahoe is offline   Reply With Quote
