Old 09-04-2009, 09:56 PM   #1
Number21
Number21's Avatar
Tallest tires on a stock C30?
I have a stock height 1979 C30 with 4.56 gears in the rear end. Trying to tame those gears a little bit, I think bigger tires would be nice. What is the biggest tire I can put on a stock, unlifted truck? Right now I think it has 31"...
Number21 is offline   Reply With Quote
Old 09-04-2009, 10:27 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Tallest tires on a stock C30?
32" will fit
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-04-2009, 10:33 PM   #3
f.monroe
f.monroe's Avatar
Remington makes a 255/85/16 and it is about 33 inches tall . Nice tire if you are running stock wheels and want a nice tire to tame that gear .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 09-04-2009, 11:14 PM   #4
b454rat
33s will fit fine. If you don't mind the woodchuck look, 39s will probly fit too!!!! lol
Buddy has 265/75s on his 3/4 ton 2 wheeler.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-06-2009, 12:49 AM   #5
Number21
Number21's Avatar
Alright, what I got now is 235/85R16 which works out to 31.7". Do you think switching to 33s would really make much difference in how the gearing feels? I could always swap over to 4.11s too, but I already need new tires...
It's hard to tell since I don't have a tach, but as it is now I think about 65mph is my top speed in 4th, LOL. I wanted a work truck but not a semi truck!
Old 09-06-2009, 01:17 AM   #6
Flat 67
Junior Member
Flat 67's Avatar
Try this:http://www.ringpinion.com/Calc_RPM.aspx
It is a RPM calculator. It is kind of fun to try different values................Flat67
Flat 67 is offline   Reply With Quote
Old 09-06-2009, 08:56 PM   #7
Number21
Number21's Avatar
Sweet! Now I have a manual tach.
Doesn't look like changing the tire size will help much...I'm starting to lean towards...I can't say it....OVERDRIVE!
