Old 09-05-2009, 11:15 AM   #1
chevy283
chevy283's Avatar
th350 problems
I installed a th350 in my truck worked fine till i hauled a horse trailer. Now it starts bogging down when i get up to 3000 rpms it shifts great just wont hold the speed. any help would be great. thanks
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 09-05-2009, 02:27 PM   #2
Eagar1
Re: th350 problems
bogging is a term usually reserved for carb issues, is it losing power? or is the tranny slipping? could be the torque converter, or even a bearing.
Eagar1 is offline   Reply With Quote
Old 09-05-2009, 11:40 PM   #3
Captainfab
60-66 Nut
Re: th350 problems
Was this a newly rebuilt TH350 with a new torque converter, or was it a used trans and torque converter? What engine do you have?
Old 09-06-2009, 01:01 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: th350 problems
I agree with Captainfab. Give us more info so we can help.
What is your rearend gear ratio? Stall of your convertor?
What size motor do you have? 283?
Cam?
Is the engine built to run properly with the trans? (The stall)
You are pulling a horse trailer. That's a lot of weight. Need a low gear, but it should match the engine, trans(stall convetor).
Check this link out: http://67-72chevytrucks.com/vboard/s...d.php?t=345759
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 09-07-2009, 12:34 PM   #5
chevy283
chevy283's Avatar
Re: th350 problems
Ok here's the setup. 78 305 with power pack heads 4 barrel 1406 edelbrock carb. 3.73 rear the th350 i got used from my cousin he had it rebuilt with a shift kit it has about 5000 miles on it. the horse trailer only had one small horse in it.
65 c10 tore apart
70 c10 305/350th
Old 09-07-2009, 12:36 PM   #6
chevy283
chevy283's Avatar
Re: th350 problems
It gets up to speed great but wont go over 3000 rpms it just makes a weird noise kinda like its just sucking air which would be the carb i would think.
65 c10 tore apart
70 c10 305/350th
