Old 09-07-2009, 12:16 AM   #1
tkmad
Driveshaft question
I am swapping the rear axle on my '67 from the Eaton to a Dana 60. The 60 requires a shorter driveshaft. The one in the truck right now is 2" diameter and I have a back section, the shorter one, but it is 2.5" diameter.
Will there be any issues with having a driveshaft that is 2" front and 2.5" back?
tkmad is offline   Reply With Quote
Old 09-07-2009, 12:30 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Driveshaft question
some gm shafts are smaller on the ends than they are in the middle, sometimes when we shorten those we have to cut into the larger diameter part of the tube so we use a weld yoke designed for that diameter tube. so that answers if its ok to have a driveshaft tube that varies in diameter from one end to the other.
but if youre asking if you SHOULD weld 2 driveshafts together in the middle somewhere HELL NO!
its not very expensive to have a driveshaft shop shorten and ballance a driveshaft with the propper ends to accept the appropriate u-joints.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 09-07-2009, 01:48 PM   #3
Green Machine
Green Machine's Avatar
No problem on the different shaft sizes, many were that way from the factory with a fatter rear half. Our 1970 is that way.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
