#26 |
Re: Blazer Quarter Fix - Using SWB Bedsides
Did I see 2 rust free blazer tubs for sale??????
#27 |
#28 |
Haven't looked yet, did this make the FAQ section as requested?
#29 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Im glad I saw this as I think I am gonna go this route....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#30 |
#31 |
PROJECT 7DEUCE
Mine needs new doors fenders and quarters.. I have the new doors just need to get the time to install and order the quarter panels. My quarters are sooooo full of bondo its not even funny...
#32 |
Has anyone seen the curved piece that gets sandwiched between the panels above the tire offered as a patch panel? Or will this have to be made or taken from a donor? It looks to extend the wheel arch into the outer bed side. Or is it part of the inner bedside? That's what it looks like in the pics of your donor swb side on the sawhorses. Is it attached at the bottom of the whole outer wheel well? Did you remove the rear bed stake from your donor as to use yours for alignment? It looks that way, just wonder how you tied the rear in around that area. Sorry for the thousand questions in a row.
'66 ![]() '72 ![]() |
#33 |
This will probably help you a lot.....
Here's what a Tri-Pro replacement bedside looks like: ![]() Details on the inner bedside (taillight end): ![]() Inner bedside...(B-pillar end): ![]() And if you have the guts to immediately cut apart a brand new $500 part.... ![]() In that last photo, you can see that the intermediate panel you are looking for IS part of the complete bedside assembly. I only wanted the outer skins for my repairs, and I was disappointed at just how much of what I'd paid for ended up geting "wasted"..... I didn't throw them away or anything, but in reality, I only ended up using about $200 worth of the panel (on a percentage basis). Hope that helps! -G ![]()
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
#34 | |
Make any better sense now? Last edited by vtblazer; 02-24-2010 at 01:34 PM. |
#35 |
Thanks for the additional pics. That's awesome. Now I know which route I'm gonna have to go. Mine don't exsist...Wisconsin winter road salt+38yrs. Grrrrrrrrrrrr!!
'66 ![]() '72 ![]() Last edited by Dzlhead; 02-24-2010 at 05:46 PM. |
#36 |
vt i should just send my blazer up to you so you could rebuild the body on it . you do some very good metal work
1970 k/5 blazer--> money pit - 14bolt dana 44 350 sm465/205 36 14.50 16 tires 1972 nova plane jane 6 clyinder might sell might keep dont know 2004 chevy s-10 crewcab zr5 sold 1985 c20 chevy long bed , beater , on its way to a better place in pa from what the dmv told me 2010 kia forte koup 2.4 sx -over the river and threw the woods to the total lot it went . 1999 k1500 suburban 350 vortec 4l60e leather land yacht . |
#37 |
#38 |
Future TOTM Winner
I wish it was possible to just get the full outer skin, heck maybe it is possible and I just don't know about it. Seems like it would be real easy to pull them off the line before it and the inner panel got welded together. It would save someone doing this type of repair a lot of cash.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#39 |
As long as we're bringing old threads back to the top, I think this is a great one.
#40 | |
This is how it gets finished up. * Test fitting the front of the quaurters, this is all that get's removed, the rest of the panel is the same as a blazer. Last edited by vtblazer; 10-10-2010 at 07:23 AM. |
#41 |
*Stitching it back together and the pass side install.
#42 |
Starting the drivers side, complicated by the existing flush mount gas door.
W/first test fit up. |
#43 |
B pillar work, drivers side.
Self taps work great, when removed, simply fill in the hole. |
#44 |
C pillar detail and onto body work.
#45 |
...lots of body work.
#46 |
Out in the light of day and how it turned out in the end.
May not be everyones idea of the 'best way to do it' but with what I had to work with, it was for me hands down. I'd do it again this way too, leaving the 'b' & 'c' pillars intact worked really well. |
#47 |
USMC
Did you weld all the way across the top of the bed rail? Looks butted up, not holes and spot welded like down the pillar.
If you noted it sorry, the A.D.D. kicked in and I could not read every word, but I didn't see anything about it or a pic of it welded up there.
Semper Fi |
#48 |
Yes, the entire seam got welded but in sections to avoid over heating.
#49 |
![]() Join Date: Sep 2010
Was the front seam just filled or did that get welded as well? Thanks and great work.
#50 | |
Where the skin meets the 'b' pillar as in the pics? |
