Old 09-08-2009, 09:02 AM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Help: Looking for: Tank Filler Neck
I have to replace my fuel tank on the Blazer. No help for it... I'm going to replace with a steel replacement but the filler tube has to be exchanged from the old to the new. Mine is rusted around the end and if I trim the bad spot out (shorten) it will be right on the bend. Yeah it will probably leak. I know that this will be a hard find, as no on likes cutting up gas tanks. But hey... gotta try!
Thanks, David
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 09-08-2009, 10:01 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Help: Looking for: Tank Filler Neck
Will JBWeld hold up under gas? Since ya gotta cut it off, you could braze or solder it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-08-2009, 10:09 AM   #3
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I can make it work, one way or another. I'm just particular about repairs like this. I would like to just install a good filler neck on the repacement tank. Thanks for the suggestion though...
Old 09-08-2009, 12:34 PM   #4
jaros44sr
jaros44sr's Avatar
Any muffler shops with a mandrel bender in Fla.?
SAFETY FIRST
AS usual, off topic
Jim
Old 09-08-2009, 12:39 PM   #5
JimmyFloyd
I have a tank I'm not going to use, but I don't think the fill tube is that long. I will check though. If it is, I'll hack it off for you.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 09-08-2009, 01:22 PM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Jimmy, If its the original tank it will look exactly like the one in the picture. If you would, could you cut the tank and not the filler tube (pictured). I will desolder and solder in the new tank. In the picture, the partial rubber hose is still attached to end. Thanks
Old 09-08-2009, 06:51 PM   #7
vtblazer
vtblazer's Avatar
I sent that exact same patch out to someone a few years back, it happens.
vtblazer is offline   Reply With Quote
Old 09-08-2009, 10:44 PM   #8
JimmyFloyd
Huh, well what do you know? Make me an offer, and what is your time frame? I also need to make sure that the suburban tank I have won't need this, but I am pretty sure it won't.
Old 09-09-2009, 06:38 AM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Jimmy, I think sub tanks are a little different, But thanks, PM'd you. DP
Old 09-09-2009, 09:24 PM   #10
Mike C
Mike C's Avatar
Why not just cut it back and run a longer hose? Or am I missing something?
Edit: Oh, I should read closer... I' think it will be fine on the bend. Make up for not having the ridge to hold the hose anymore.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-14-2009, 05:36 PM   #11
skidder111
skidder111's Avatar
D.Passmore - PM me if you're stuck. I got an old tank out back, but it's a long way from your part of the woods. The neck is about the only good thing left on it.
skidder111 is offline   Reply With Quote
Old 09-14-2009, 06:04 PM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Will Do, Thank you.
Old 09-14-2009, 11:31 PM   #13
bbarooo
bbarooo's Avatar
I've got one going to the trash can but I think the filler is good. PM me if nothing works out for you.
bbarooo is offline   Reply With Quote
