Old 04-08-2003, 08:21 PM   #1
crazy longhorn
Fabricate till you "puke"
Its alive!
The old longhorn has been upgraded to a 6 spd richmond trans. Hays billet 400 sb flywheel,centerforce dual friction clutch, ARP fasteners, modified stock clutch linkage with rod ends& a little carvin on the firewall to get a straight push on the parts. The trans crossmember was modified(notched & tab added to keep the drive line angles in check). She has been run in on the stands, & speedo gears set up. Ratios on the trans are 3.28, 2.14,1.57, 1.24,1, .76. With the 4.10 gears she will be redline in low @ 37 mph......6th gear will put me @ 100 mph @ an easy 3750, just a tick above peak tork on that 383! The snow/rain has put a damper on the road test, but it looks like i need to pull an axle on that 12 bolt ( me think she be twisted!) Oops! when we play, Iguess we have to pay crazyL, ready jam some gears
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-08-2003, 08:31 PM   #2
meathead95
computer illiterate
meathead95's Avatar
congrats sounds like an awesome upgrade
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-08-2003, 08:53 PM   #3
krue
Designated A-hole!
krue's Avatar
Sounds like way too much fun!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-08-2003, 09:05 PM   #4
crazy longhorn
We cant never have too much fun
Old 04-08-2003, 09:14 PM   #5
racedvl
racedvl's Avatar
racedvl is offline   Reply With Quote
Old 04-09-2003, 01:24 AM   #6
wHATANERD
wHATANERD's Avatar
Cool
Sounds Fun!!!!!!
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
