Old 09-12-2009, 02:54 PM   #26
panhandler62
Java Mechanic
panhandler62's Avatar
Re: what will pancaking the crossmember gain me
Originally Posted by SCOTI View Post
While good advice, it doesn't work for all. If I click that 'search this forum' button, I get nothing. Same w/the 'forum tools' selection.
If you are using the "lightblue" theme a lot of features won't work. I like the look of that one better, but I switched to the default because it works better.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-12-2009, 03:28 PM   #27
SCOTI
SCOTI's Avatar
Ahhh. . .... That made the difference. Gracias.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-12-2009, 07:20 PM   #28
Wild83C10
Wild83C10's Avatar
Originally Posted by 67cheby View Post
For your information 83 i searched several times kept coming up with the same things so i wanted some more information, if that is ok with you, maybe i should start asking you before i post anything !!!
This was posted on 8/20/2009 with links and plenty of info. Everyones memory that short?
http://67-72chevytrucks.com/vboard/s...hlight=pancake
Not trying to give everyone a hard time. Like I said, instead of having 5,6 good threads with all the info we have to search through 200 to find the same info because the same questions get asked every week. If you see a thread with some of the answers post to that thread and bring it back to the top.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-13-2009, 03:47 AM   #29
Primer70
Superbad
Primer70's Avatar
Originally Posted by smashingchuck View Post
You can raise the crossmember 1.5" and have zero adverse effects on the steering. The upper a arm clearance is easily fixed with the Flaming River joints and shaft (I literally built mine in 30 minutes). Raise the steering the same amount as you do the crossmember and you will be home free. Or figure out the correct rack and pinion to use.
If you raise the steering the same amount as the amount you section the crossmember the steering will keep the geometry the way it's supposed to be, but at that point Z'ing the frame is less work. But I've gotta question, if your gonna raise the steering with the sectioning of the crossmember why only go 1.5"?
Primer70 is offline   Reply With Quote
Old 09-13-2009, 01:20 PM   #30
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
That's all I needed to lay out on my tires (27").
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
