Old 09-13-2009, 04:37 PM   #1
profe56
Rear end conversion
Someone in the forum has installed or swap a rear end from 73 and up in a C10 67-72 1/2 ton can I see pictures if you have made this conversion.
profe56 is offline   Reply With Quote
Old 09-13-2009, 05:36 PM   #2
BCOWANWHEELS
Re: Rear end conversion
73+up is leaf springs
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-13-2009, 05:37 PM   #3
57larry
73 & up have leaf springs. I'd be interested if you can use the 73 with some sort of coil spring conversion
57larry is offline   Reply With Quote
Old 09-13-2009, 05:40 PM   #4
highperf4x4
Why convert the springs? The 67-72 GMC's had leaf springs too. Get your spring mounts from one of them.
highperf4x4 is offline   Reply With Quote
Old 09-13-2009, 05:42 PM   #5
90\87Formula
90\87Formula's Avatar
Check this link for a conversion kit. http://www.classicperform.com/Store/...ck/6072RCK.htm
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 09-13-2009, 05:53 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've done it a few times. Here is an 80 model rear I converted a few months ago.
Remove shock mounts and spring pads.
Weld on new coil spring saddles (ECE parts)
Powdercoat:
Use ECE Super Track bar to locate the new rearend side to side.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-13-2009, 06:03 PM   #7
Pont406
Did you use a mig welder? I might try this.
Pont406 is offline   Reply With Quote
Old 09-13-2009, 06:05 PM   #8
Tx Firefighter
I don't remember which I used. I use stick welder or MIG depending on which stage of the moon we're in that day. Any kind of welder that has proper power will do the job. It looks like I used MIG though.
Old 09-13-2009, 06:14 PM   #9
90\87Formula
Originally Posted by Tx Firefighter View Post
I've done it a few times. Use ECE Super Track bar to locate the new rearend side to side.
What about the shock mounts?
Robert
Member 1532
Old 09-13-2009, 06:20 PM   #10
Tx Firefighter
They don't have anything to do with the rearend on a coil spring truck.
Old 09-13-2009, 06:33 PM   #11
90\87Formula
I understand that, as far as installing the rearend; but we don't want the truck continually bouncing.
Robert
Member 1532
Old 09-13-2009, 06:40 PM   #12
Tx Firefighter
I guess I am still confused. The shocks mount to the trailing arms. To do this swap, you don't have to fool with the shock mounts at all.
Old 09-13-2009, 06:51 PM   #13
90\87Formula
My bad. It's been a really long time since I actually looked/noticed where they were mounted. Never did any work on a rearend, except change the brake shoes; many years ago. AND my truck hasn't been street driven in at least 9 years.
Sorry for hijacking your thread profe56
Robert
Member 1532
Old 09-13-2009, 07:41 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Out of morbid curiosity, why go from a 12 bolt to a 10 bolt rear?
Old 09-13-2009, 07:47 PM   #15
57larry
my 73 has a stock 12 bolt
Old 09-13-2009, 08:33 PM   #16
haysonj
haysonj's Avatar
Here's a 73 14 bolt in a 69 4x4 I had to move the spring perches out as I widened the springs out 2 inches to get more stability for towing.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 09-13-2009, 08:58 PM   #17
Tx Firefighter
Who me ? That is a 12 bolt out of the 80. I did it for 5 lug and highway gears.
Old 09-13-2009, 09:20 PM   #18
profe56
Thanks TX FIREFIGTHER for the pictures and everyone taking part in the topic for all the information, the project to use a newest rear end is because I upgrade front disc brakes in my 69 C10 and firstable I need 5 lugs in rear, second I would probably find out a pos rear end, there is in Otay Mesa junk yards where you pic your parts and pay not much. is there any way to see if a rear end is pos without open the cover?
the rearend must be same wide, is there any problem alignament if is more or less wide
thnk you
Old 09-13-2009, 09:29 PM   #19
Longhorn Man
i thought they went to a 10 bolt in 73.
Thanks.
Old 10-11-2009, 04:17 PM   #20
dragitvinn
Can anyone help
I have a 69 Chevy c20 with a 8 lug rear end. I bought the truck used and don't know where the rear came from.. when i drive the truck i get shaking from the back of the truck at about 55-65mph.. I looked under the truck and it looks like the rear diff tilted down where it meets the drive shaft... It also is not centered to the truck its over towards the pass side 1 inch.. Can the rear being off centered be adjusted with an adjustable pan-hard bar? Should it be tilted downward toward the front of the rear end?
dragitvinn is offline   Reply With Quote
Old 10-11-2009, 04:23 PM   #21
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
[QUOTE=Tx Firefighter;3516478]I've done it a few times. Here is an 80 model rear I converted a few months ago.
How did you figure out where to weld the saddles?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-11-2009, 04:30 PM   #22
dragitvinn
Is it suppose to be on a downward tilt?
1972 Chevy suburban sale
Old 10-11-2009, 09:36 PM   #23
profe56
I still looking on the rearend I could buy, but CHEVY or GMC Vans could be an opption too?
because I saw a lot specially vanduras, 10s,20s and 30s.
How do you think are the ratios in vans?
Old 10-11-2009, 09:49 PM   #24
joe b
A van rear will be too wide
joe b is offline   Reply With Quote
Old 10-11-2009, 11:00 PM   #25
chevy_mike
Never Ending Projects
chevy_mike's Avatar
[quote=Already Gone;3563196]
I did this same swap, '73 C10, which gave me 5 on 5 lug pattern and 3.42 gear (stock is 4.11 in my '68 rear end).
Using an angle finder to setup the saddle angles. I checked what stock was and just set everything on the '73 rear end to match. As for side to side, lots of measuring, to make sure they were equal distances from the brake flange. Tack welded the saddles then took the rear end back out and did the full welding on jack stands, where it was easier to get to.
Angle finder
Welded up
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
