#26 |
Re: post latest 1/4 and 1/8 mile times and 60ft.
djracer thanks for the welcome
69trk never thought truck would hook so hard with all stock hardware still smiling |
#27 |
heres my best out of three runs haven't been back since i got slicks and track bar.will post new times soon. as for now i got the slowest truck lol
60' 2.218 330 5.884 mph 62.30 1/8 8.943 mph 77.54 this run was with 454 th400 ford 9 in 4.56 gears spool 33x21.5x15 sportsmans |
#28 |
This should become a sticky IMO..
Post your newest info and I'll update the spreadsheet..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#29 |
Maybe we can make it one oneday!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#30 |
10.61@126.75 1.54 60'
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#31 |
7.18@93mph, 1.56 60ft...
#32 |
I did more carb tuning.
11.98 at 109, had a 1.73 60ft and a good headwind so it improved. |
#33 |
ask and you shall recieve...it's sticky now
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#34 |
Jim... Glad to see you around
#35 |
Junior Member
![]() Join Date: Mar 2005
This was the end of last year. This year we get a new converter ,rear springs and spray it. Hope to get it in the 12s on the motor and 11s on the juice..
60' 1.872 330 5.432 1/8 8.405 mph 82.29 1000 11.006 1/4 13.225 mph 101.43 weight 4500
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82 12.39 @111.33 With a 180 shot nos 69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/ email fdelcoglin@hotmail.com Last edited by franks72; 03-11-2009 at 07:48 PM. |
#36 |
Name 71chevytruckguy
Date 03/07/09 60' 1.811 330' 5.453 1/8 ET 8.478 1/8 MPH 82.736 1000' n/a 1/4 ET n/a 1/4 MPH n/a Year 1969 Weight ??? Engine Platform (Cubic inches and SBC, BBC, BBF, LS-series, Hemi) 377 SBC Transmission Muncie M-20 Stall converter dumping the clutch at 4000rpm Power adder 1 none Power adder 2 Power adder 3 Rear Gear 4.88 Rear Tire 28x10.5 M/T ET drag Comments pump gas all motor Chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
#37 |
Hay Team!!
![]() Join Date: Jun 2003
Mine has a best of 7.36 @ 93mph in the 1/8th
That was a 1.61 60 ft. LWB, Trailing arms, 10 inch wheel and MT Drag Radial The new setup should be in the 6's...we will see soon
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
#38 |
certified tard
finally went out. i havent done anything to the truck except hook up the vacuum advance, tint the windows, and run premium. that open diff is killin me, i was thinking about going 305s in the rear or bigger. but i think a limited slip will really wake up the time and work great with the 275s. remember, im at 5000+ feet, so times are a little slower here. oh yeah, stock 8.5" 10 bolt with 2.73's. i was proud of me! ill get that lsd and see what happens, but i still really want some rallye wheels, money money money, damn it.
run #1 rt .655 60 2.638 1320 16.363 @ 81.44 run #2 rt .806 60 2.631 1320 17.614 @ 77.75 floor mat got stuck under gas pedal... Run #3 rt .555 60 2.844 1320 16.503 @ 85.41 run #4 rt .403 60 2.717 1320 16.356 @ 84.81 Last edited by spaseghost; 08-09-2009 at 07:33 PM. |
#39 |
Well i finally made it to my local track first time ever with the truck it has alittle more in it need to change gears crossing the line in second gear
all motor passes 1st pass 1.68 60' 7.66 1/8 83.85 mph lifted early 2nd pass 1.60 60' 7.45 1/8 88.70 mph adjusted timing 3rd pass 1.75 60' 7.65 1/8 89.57 mph spun out of the hole _______________________________ 1968 c-10 stepside "THE GRAPE APE" all motor 1.56...60ft 7.41...1/8 89.41..1/8 Last edited by limitedstreetoutlaw; 11-18-2009 at 03:30 PM. |
#40 |
certified tard
two new ones from 8/28/09
rt .508 60 2.897 660 10.893 @ 69.29 1320 16.679 @84.48 still having traction issues second run just had the track cleaned after a spill, i was first! i went against my dads 68 camaro ![]() 0.223 rt .244 2.510 60 2.723 6.840 330 6.832 10.400 660 10.132 69.82 mph1 74.39 13.393 990 12.890 16.169 1320 15.409 84.29 mph2 92.74
85 swb bbc 5% tint 16.356 @ 84.81 8/07/09 4800 Ft., bad timing, carb tune, and traction, fugg it. 16.169 @ 84.29 8/28/09 good timing, no carb tune, some traction... 06 Equinox LT AWD, wife's and family ride 03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?! 90 Eagle Talon, other project / space taker, GOT head!! 08 Silverado 2500 HD, the bad ass work truck |
#41 |
Learning how to take off and where to **** my new bullet.
11.13 at 117 |
#42 |
At the body shop.
Super73? hows your 73 coming havnt seen any new pics over there. Any how .012 rt 1.671 60 ft 4.95 330ft 7.71 1/8th 88.71 mph 12.20 1/4 108.1 mph sbc 406 th 475 tci 3500 ish verter 3.82 gear 9 inch cal tracs hoosier 325/50 drag radial.
#43 |
Nice pass.. Truck needs a little tuning but I did drive it to a car show a week or so ago.. I think the new intake is loading it up.. Weird how an intake change can make this thing go soooooo rich.
#44 |
It seams i can just change a nut on the fender, and mine will run different
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#45 |
At the body shop.
super 73 good to hear the car moves. the pics on nc1320 were awesome
#46 |
Mean Green
Name68 C-10
Date9/11/09 60'1.664 330' 1/8 ET7.670 1/8 MPH88.94 1000' 1/4 ET12.223 1/4 MPH106.62 Year68 Weight4013lbs w/ 8 gal of Fuel Engine Platform SBC406 TransmissionTH400 Stall converterHughes 4000 leaving @ 3600 RPM Power adder 1na Power adder 2na Power adder 3na Rear Gear4:10 Rear Tire28x13.5 ET drag MT CommentsI'm not sure were some of my power went to. End of last year it ran 12.0 around 109mph. I have done leak down and comp test all is good. Next up Valve spring test. |
#47 |
Was the air the same?
#48 |
I was going to say DA effect's possibly.. It's amazing how much of an effect it can have..
#49 |
Dr. Frankenstein
wasent it like 90* that day? were you at Woodburn or PIR?
I Wanna Go Fast!! |
#50 |
Mean Green
I don't have any thing to test air levels to see if they are high or low.
I have only went 12.0's @ Woodburn and 12.1's at PIR. I'm not on board w/ the abbreviation Of DA. I did put a new ss blaster coil on last night. I need to OHM my old one. I'm borrowing my machinist spring tester this weekend so I can check springs on the heads in truck. I need to invest in log book real bad. |
