Old 09-15-2009, 06:32 PM   #1
Roadhammer
Roadhammer's Avatar
Differnt fly wheel for a TH400?
I pulled the tranny and clutch off the engine and the torque converter doesnt look like it bolts right up...would I need a different flywheel?
I really know next to nothing about this sort of thing.
Jory
Help...
Roadhammer is offline   Reply With Quote
Old 09-15-2009, 06:57 PM   #2
198plus
198plus's Avatar
Re: Differnt fly wheel for a TH400?
You will have to change flywheel.
Jory
Help...
198plus is offline   Reply With Quote
Old 09-15-2009, 07:57 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
You're not providing much information to go on. What year and engine are you dealing with and what did the T400 come out of. There are basically two size of flywheels and flexplates, 153 tooth and 168 tooth. If you go to a website like Summitracing and search under flexplates, they are organized by application. This spells out what year and size engine each type fits.
Old 09-15-2009, 11:04 PM   #4
Eagar1
Your MT had a flywheel, your TH400 requires a flexplate, and usually it doesnt matter which flexplate you use as long as you can mount the starter on your block that matches it. I believe the smaller tooth uses the straight across bolt holes starter mount and the larger tooth uses the offset mounting. I know this was discussed on another thread but I can't remember which one.
Eagar1 is offline   Reply With Quote
Old 09-15-2009, 11:12 PM   #5
Captainfab
60-66 Nut
Ron pretty well summed it up.....sounds like you will need a flexplate. More than likely a 168 tooth one. Get one with the same tooth count as the flywheel that is on it now so you don't need to get another starter. Plus when you do need a starter you just need to ask for one for a '70 Chevy C10
