#1201 |
Can't wait to retire!!
Re: PO has me PO'd
Glad things are looking up.
![]() Just had to call in the master.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#1202 |
![]() Join Date: May 2006
Re: PO has me PO'd
![]() Hard to tell but it is painted in white gravel guard, second pic. shows alignment hole for a tapered punch ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-17-2009 at 02:05 PM. |
#1203 |
![]() Join Date: Apr 2009
Re: PO has me PO'd
lOOKS SWEET STAY MOTIVATED DEVIL!!!!!!!!!!!!
1937 Pontiac 2dr 1970 K5 CST 1972 Jimmy 1973 Hickey ent. equipped Blazer 1977 Blazer Chalet #1193 |
#1204 |
Re: PO has me PO'd
Thanks Ariz., working on the motivation, but this old girl has fought me every step of the way
![]() Next project is finding a 1 ton 2 speed rearend Yeah, I know I have to adjust my headlights ![]() Since I have NOS van lights I have to make up a bracket. You can see why my headlights are out of adjustment ![]() Horn wire is the last of the plug and play for this side...problem is the PO had 6 horns mounted down there. Gotta find out what is stock ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-06-2009 at 01:55 PM. |
#1205 |
Re: PO has me PO'd
you gonna run one ton running gear huh?? i love bone stock blazers, but can't argue with the beefy axels!! keep up the good work if you were closer i'd buy you a beer? since ur in pa you ever been to tun taven?
#1206 |
Re: PO has me PO'd
She's looking good Jim. Keep pluggin away!
#1207 | |
Re: PO has me PO'd
One tons aleast on the rear end, someday I may switch over to a Dana 60 on the front...but then I would have to change my name Can't say that I was there, should've been...wife wants to go to the Marine Corps Ball. My Brother is going to the one at 3rd and I this year
#1208 |
Re: PO has me PO'd
Nice i miss the Marine Corps Ball good times there!, my wife also mentioned on how she would like to go again but i didnt know you could go if you were not still active!
#1209 |
USMC
Re: PO has me PO'd
Tun Tavern no longer exists, having burned down in 1781. Its original location is now occupied by Interstate 95. The National Museum of the Marine Corps in Quantico, Virginia contains a Tun Tavern-themed restaurant with a lunch menu and alcoholic beverages and bread pudding.
Semper Fi
Semper Fi |
#1210 |
Re: PO has me PO'd
interesting!
#1211 |
I miss this truck.
Re: PO has me PO'd
Jim, Don't know how I missed this until now. I'll check it out tonight ad let you know.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#1212 |
Re: PO has me PO'd
Thanks bud...just down there now working on that side, I was going to steal the drivers side one
![]() Should fit in a flat rate box, if you live near a Post Office
#1213 |
Re: PO has me PO'd
Geeeze...three days without an update!
![]() Stop putting it off...someday you DO have to finish it ya know. ![]() |
#1214 |
Re: PO has me PO'd
Sorry, computer went down! Had to do a system restore, whatever that is!
PICS to FOLLOW-third attempt to install headlite buckets sounds easy right! WRONG!!!!
#1215 |
Re: PO has me PO'd
is it done yet?
#1216 |
Re: PO has me PO'd
#1217 | |
Re: PO has me PO'd
#1218 |
Re: PO has me PO'd
Hey Jim,
You feelin' okay...? Almost a month since your last update. Oh I know, your gonna surprise us, aren't ya? ![]() |
#1219 | |
Re: PO has me PO'd
Wagner Halogen Headlights, really white light, 25 bucks a pop. The new relays really put the power to the lights, keeping it off of the 40 year old switch ![]() Thanks Tynee for the voltage regulator, good people on this board ![]() New relays for the electric fan and the electric water pump ![]() working on the electric fan install...had to modify the alum. rad. mounts again, this time it was because the harness got thicker with the relays on the passenger side...hindsight, mount all the relays on the drivers side ![]() Ended up cutting the mount horizontal, then making two cuts vertical with the cutoff wheel, then tapped the end back to close up the joint ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-20-2009 at 01:13 AM. |
#1220 |
Re: PO has me PO'd
Good job Jim, are we driving the Jimmy to Kurt's?
#1221 |
Re: PO has me PO'd
Don't do it, we use salt on the roads in the winter...lots of salt. ![]() Jim, I've used those relays for the headlights before too, it's an excellent mod for sure. Nice report, didn't know you were injured, sorry to hear it, thanks for jambing around on the walker to get the pics tough. ![]() |
#1222 | |
I miss this truck.
Re: PO has me PO'd
Sorry to hear you weren't feeling good. The Jimmy's really starting to look like a truck now...
#1223 |
Back in the sticks
Re: PO has me PO'd
Looking at that pic of the relays reminds me I want to add side markers to my Blazer. Can you look at your harness and see which wire the side marker lamp taps off of? I don't know tho, its looking a lot like a nearly complete truck to me! Keep up the good work, Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#1224 | ||
Re: PO has me PO'd
That only gives me 4 months to finish it and, well...you know how slow I work ![]() Nicely done on your signature, very respectful! Honestly, I don't know how I would handle it after 37 years. Anytime ya want to talk, ya got my numbers
#1225 |
Re: PO has me PO'd
![]() could be the last time to mount the rad. on the core support...maybe ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-21-2009 at 12:17 PM. |
