#51 |
Re: lowered shortbeds on stock wheels?
Working, lowered, & on Ralleys . . ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-15-2009 at 10:58 PM. |
#52 |
mine
a coil and 3 inches cut off the front springs, and the short, thick overload leaf and 2 other removed from the rear pack leaving 3 leafs 8 inch rallys with 235/75/15's it is under going some renovation at the moment ![]()
![]() ![]() Last edited by joe231; 09-16-2009 at 12:13 AM. |
#53 |
.. !WAR FEDOR! ..
can you give us some more specs on you truck? drop and tire size??
"san diego chargers #1" |
#54 |
TuTone Silverado
![]() Join Date: Mar 2007
Here they are 20X8.5
13 Corvette GS vert 13 Ram Laramie Longhorn 11 Wrangler Sahara unlimited 08 300 76 El Camino 67 Bel Air sedan 63 Corvette SWC 08 HD Road King Classic 68 HD Golf car |
#55 |
StepinNJ, What is you drop and back-spacing?
#56 | |
1-coil cut off OE V8 springs 1-ton 1.25" sway bar on Energy Suspension bushings Gabriel replacement gas shocks w/owner fabbed upper relocation bracket 215-70-15 BFG's on 15x6.5" van ralleys shaved lower a-arm lip @ BJ area for wheel clearance Western Chassis flip kit (HD 8-leaf spring option) Bell Tech shackles WC bolt-in c-sections (bolted-in w/GRADE-8 hardware + welded WC shock extensions Gabriel gas shocks for 73-87 GM 4x4 front Owner fabbed air-over leaf set-up (manual fill w/schrader valves) 255-70-15 BFG's on 15x8" truck ralleys Hidden CLASS IV Hitch
#57 |
Captain Thorough to the rescue!!!
![]() excellent info ![]()
#58 |
heres my old 85...
van ralleys on front and wide truck ralleys on the rear. i can remember the front tire size but the rear is a 275-60 drag radial. ![]() ![]() |
#59 |
What was the setup on it?
#60 |
a 6/8 drop
#61 |
![]() Join Date: Jul 2009
Here is a shot of mine.
It has a 2.5" spindle on the front with a Belltech 1" coil that I actually cut a 1/2 a coil off of, for a total of about 4.5"in the front. The rear is just a flip bracket that I made due to the '96 rearend swap. I replaced the shocks in the front with Belltech Nitro Drop shocks and replaced a few bushing and the upper balljoints at the same time I installed the drop. After doing all of that, it actually rides a heck of a lot better than it did in stock trim. It has 15x8" rallies w/ 255/70r15's which calculate out to about 29" tall and they do NOT rub at all. I have future plans for 18" wheels but no bigger because I tow a ski boat with it, and don't want to ruin the ride. |
#62 |
^^ your truck sure looks sick buddy.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#63 |
Thanks, It's still a work in progress though. Gotta have that 5.3L
#64 | |
.. !WAR FEDOR! ..
#65 |
The measurement's when I started vs. when I finally finished the drop at the fenders works out to 4.5" front and 5.5" rear. I'm not totally convinced that I want to notch the rear frame because the rearend only hits the frame if I hit a hell of a bump, and I am still using the ORIGINAL rear shocks without relocators. Those are next
#66 |
Nlped this is yet another fine example of a beautiful stock looking truck. That thing is beautiful! Got a few "right click save's" in that post.
#69 |
6.0 powered square
comes with a c-notch
western chassis $500 for 4-6 and 5-7 http://sporttruckdirect.com/C10_kits.html mcgaughys 562 http://www.stylintrucks.com/parts.as...sults_trigger= beltec $630 http://sporttruckdirect.com/Belltech_Drop_Specials.html no c-notch djm 5-5 $488 http://www.stylintrucks.com/part.asp...&partid=559744 parts from summit 3" summits coils $74(ground force) http://www.summitracing.com/parts/SUM-G726/ djm flip kit $85 http://www.summitracing.com/parts/DJM-FK1024-5/ cp spindles $210 http://www.summitracing.com/parts/CLP-CP4S4/ total $369
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 09-17-2009 at 05:50 PM. |
#70 |
What is the drop you have on this?
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
#71 |
#72 |
#73 | |
#74 |
The Cheesiest
![]() Join Date: Aug 2008
not the best pic for this topic but the red & white one is lowered on rallys
[IMG] ![]() |
#75 |
here is a better one of it
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
