Old 09-16-2009, 04:19 AM   #1
Ray Rust
Ray Rust's Avatar
what shocks
my question is what shockers are people using on static drop and bagged trucks ?
Ray Rust is offline   Reply With Quote
Old 09-16-2009, 08:52 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: what shocks
Try these. They were located right below your post...
Shock absorber recommendations? LINK
Need some rear leaf shocks for 4" drop.- LINK
what shock ( for the millionth time??) LINK
Shocks for a bagged front end- LINK
kyb shocks/ part numbers- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-16-2009, 11:16 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: what shocks
Ray Rust,...
If your question is about "Brand of Shock",... alot of people use KYB's, Belltech, or Bilsteins.
As far as application,... a mild bag job using stock upper and lower a-arms, and trailing arms,... you can use the same length shocks as you would use for a 4/6 drop.
It's when you get into tubular a-arms and 3-link or 4 link rear suspensions, that you need to contact the manufacturer of the components for the proper shock.
What did you have in mind for your suspension? Static or bags?
Keith
Convert to disc brakes.
Old 09-16-2009, 02:01 PM   #4
XXL
Señor Member
XXL's Avatar
Re: what shocks
Or, in Australia, "right ABOVE your post."
XXL is offline   Reply With Quote
Old 09-16-2009, 09:44 PM   #5
Ray Rust
Ray Rust's Avatar
Re: what shocks
Thanks N2TRUX I realised after I hit the button .. is there any reason why i can't post a reply to my thread ??? cheers from down under
Old 09-16-2009, 09:48 PM   #6
Ray Rust
Ray Rust's Avatar
Re: what shocks
Ray Rust,...
Lolife 99 ..... I've bagged the rear and cut lowered springs on the front so I'm guessing a 6inch drop in the front and the same on the rear .... Ray Rust
Old 09-16-2009, 10:27 PM   #7
SCOTI
SCOTI's Avatar
Re: what shocks
Just bags in the rear or lowering blocks too? Shock relocators would be a good investment & you'd be able to run stock length replacement shocks on the rear @ only 6" of drop. KYB GR-2's for a high quality good riding shock.
6" of drop up front w/only cut springs doesn't sound right. How many coils have been cut off the spring?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2009, 10:38 PM   #8
Ray Rust
Ray Rust's Avatar
Re: what shocks
Scoti .......just bags on the rear so your idea might be the way to go ... thanks Ray
Old 09-16-2009, 10:43 PM   #9
SCOTI
SCOTI's Avatar
Re: what shocks
What about the front? Do you know how much coil was cut off the springs?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2009, 12:33 AM   #10
Ray Rust
Ray Rust's Avatar
Re: what shocks
Scoti ....I cut a full coil off a set of springs which where reset 3inches ... that's how i got the 6inch drop very hard running 22's no more innner guards ... oh well it looks good IMO .. Ray
Old 09-17-2009, 01:04 AM   #11
SCOTI
SCOTI's Avatar
Re: what shocks
Try these upper front brackets....
http://www.performanceonline.com/sto...me.php?cat=778
With these shocks & rear brackets (p/n 902-6372-SK) . . ....
http://www.earlyclassic.com/catalog.aspx
POL is a site supporting manufacturer & ECE is well respected when it comes to these trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-17-2009, 01:09 AM   #12
Ray Rust
Ray Rust's Avatar
Re: what shocks
Thanks for your help Scoti
