Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-16-2009, 12:13 PM   #51
bigboybodry
bigboybodry's Avatar
Re: post latest 1/4 and 1/8 mile times and 60ft.
New to the site my name is daniel bodry every one calls me dbo.
I fill like u all are family and i dont even know you! Great trucks maybe mine will be back together in a couple of months.
Old engine 468 steel headed
th400 trans reverse manual w/brake
12 bolt rear end 3:73 gear spool 33 spline
bigshot plate w/nos progressor
60 foot 147
1/8 6.9
102 mph
nos button stuck and melted 2 pistons building a new engine.
bigboybodry is offline   Reply With Quote
Old 09-16-2009, 11:41 PM   #52
Super73
Super73's Avatar
DA = Density Altitude..
BDO, glad to see you aboard.. Hope to hear some new times when the new motor is here..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-17-2009, 12:09 AM   #53
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
LOL I'm a big dummy. Yes I have noticed that DA can strip tenths away in seconds. I'm putting a new built spec converter in Friday night. They say 5-7% slip only. We will see.
68 C-10 KID is offline   Reply With Quote
Old 09-19-2009, 05:08 PM   #54
68 C-10 KID
Mean Green
Name-68 C-10 KID
Date-9/18/09
60'-1.70-1.68
330'-na
1/8 ET-7.692
1/8 MPH-89.49
1000'-na
1/4 ET-12.182
1/4 MPH-107.04
Year-1968
Weight-4089LBS
Engine Platform-406 sbc
Transmission-TH 400 W/ Brake
Stall converter-A-1 4000
Rear Gear-4:10
Rear Tire-28x13.5 ET Street's
CommentsNew converter. 2 step @ 3600 RPM @stripe was 6200 now its 5600. Track was poor. 60's were all over.
Old 10-05-2009, 11:34 PM   #55
68 C-10 KID
Mean Green
Originally Posted by 68 C-10 KID View Post
Name-68 C-10 KID
Date-9/18/09
60'-1.70-1.68
330'-na
1/8 ET-7.692
1/8 MPH-89.49
1000'-na
1/4 ET-12.182
1/4 MPH-107.04
Year-1968
Weight-4089LBS
Rear Gear-4:10
Date-10-2-09
60'-1.601
1/8 ET-7.388
1/8 MPH-91.93
1/4 ET-11.776
1/4 MPH-109.43
Year-1968
Weight-4078lbs
Transmission-[COLOR="Red"]Th 400 w/ tci trans[COLOR="Red"]
Rear Gear-4:10
Rear Tire-28x13.5 E.T Streets
CommentsTurned down 2 step to 3400 and lowered shift point to 6700[/QUOTE]
Old 10-06-2009, 12:49 AM   #56
Super73
Super73's Avatar
That's haulin there buddy.. Glad to see the changes worked for you..
Old 10-06-2009, 06:54 AM   #57
69trk
69trk's Avatar
good numbers!!! I see a cage coming up next
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 10-08-2009, 12:20 AM   #58
68 C-10 KID
Mean Green
Thanks guys. I'm glad its coming around. Now I have a good base. I can start power tuning on timing and jets now. Maybe I can get a tenth or so more out of it. Sure would be nice to get a 11.49 out of it before the tracks close.
It would give me some thing to do over winter. Body work and a Roll bar set up. Maybe a bar set up that's legal to get my license W/ help from a Speed tech N20 system.
Old 10-25-2009, 01:14 AM   #59
wyomech
wyomech's Avatar
I am new on here but sure like all the trucks.Just got mine going this summer it has a 6.0 lq9 ,4l80e with stock converter,3.55 rear no posi.my best run on street tires was. 60ft 2.29 ,1/8 9.59 ,at75.9 , 1/4 14.65 at 96.8 that was at4800ft elev.
wyomech is offline   Reply With Quote
Old 11-09-2009, 02:16 PM   #60
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Well i finally made it back to the track with the new gears improved a little somthings still holding it back on the big end still not pulling the numbers we think it should.improved the most down low trucks pulling hard out of the hole. all in all we pleased so far.
old times
8/8/2009
1.60..60ft
7.45..1/8
88.70..mph
new best time
11/7/2009
1.56...60ft
7.41...1/8
89.41..1/8
_______________________________
1968 c-10 stepside "THE GRAPE APE"
all motor
1.56...60ft
7.41...1/8
89.41..1/8
limitedstreetoutlaw is offline   Reply With Quote
Old 11-09-2009, 02:51 PM   #61
Super73
Super73's Avatar
What was your old gear/tire combo and 60's? How bout the new gear/tire combo?
Old 11-10-2009, 12:11 PM   #62
limitedstreetoutlaw
old gear/tire was a 3.73 gears tires are /325/50 drag radials old 60ft was a 1.60
i have 4.56 gears now same drag radials new 60ft 1.56
all motor
1.56...60ft
7.41...1/8
89.41..1/8
Old 11-15-2009, 04:05 PM   #63
KQQL IT
At the body shop.
KQQL IT's Avatar
New best with a slightly off 60ft. The d.a was real good that day @ 4160ish btw im the one on the left
Old 11-16-2009, 01:52 AM   #64
dave brode
dave brode's Avatar
'71 C-10.
Combo run in '08 with closed exh and 29x18.5 mickey sportsman pros;
Re-ringed std bore, std crank 1975 Cadillac 500. Howards 292/302 - 232/240 at .050" cam, .536" on a 112 in 6* advanced. Ported heads and intake but all stock internals except for cam and valve springs, stock 2"/1.625" valves . Edel performer, 1" open spacer, QJ, 1.875" headers. 8.6-1 compression. 2000/3000 stall switch-pitch convertor, 4.10 gears.
12.97 at 100.02 in 1/4
8.12 at 82.19 in 1/8
1.72 sixty foot
on 87 octane.
Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108.
dave brode is offline   Reply With Quote
Old 11-16-2009, 02:02 AM   #65
dave brode
dave brode's Avatar
'71 C-10
Combo run in '09 with closed exhaust, and 29x17 M&H dot tires;
.060" over Cadillac [514"]. 11.7-1 CR, MTS/Probe 19cc dish pistons, PEP I beam rods, ported early iron heads, MTS 2.19/1.84" valves, Potter/Probe shaft roller rockers. Elgin 300/294 - 260/254 at .050", .640"/.624" solid flat tappet on a 114*, advanced 3*. 1.875" headers, Edel performer, 1" spacer, 4781 850. Switch-pitch TH400 with Tri-Shield 1800/3200 stall, 4.30s.
Best e.t - 11.66
Best mph - 113.96.6
Best 1/8 - 7.34 at 91.4
Best sixty - 1.59.
Dave
Old 11-16-2009, 07:34 AM   #66
69trk
69trk's Avatar
Nice truck david!!! Do you have any pictures?
1.58- 60'
11.37- 1/4 @115.81
Old 11-16-2009, 12:17 PM   #67
dave brode
dave brode's Avatar
Thanks trk69. I loaded pics in the picture thread, see post #225 and 226.
http://67-72chevytrucks.com/vboard/s...62#post3622862
Dave
Old 12-22-2009, 09:25 PM   #68
paul1969
paul1969's Avatar
finally made it to the track it was cold as all get out though. think there may still be some left in it. guess i'll have to wait till next year to find out.
69 stepside 489ci
60ft---- 1.46
660ft--- 6.570@105.95
1320ft-- 10.37@127.01
paul1969 is offline   Reply With Quote
Old 12-26-2009, 02:52 AM   #69
Super73
Super73's Avatar
Right on.. Nice times..
Old 01-03-2010, 03:24 AM   #70
AKoldstyle
AKoldstyle's Avatar
how quick do you think a 1972 blazer with a 598 around 800hp with 3.90 gears,29.5 mt et drag radials,a th400 w/o footbrake and a tight 3200 ati converter. rear suspension is ladder bar coil over and vehicle should way about 3000lbs. Im thinking it should run in the low tens. its all metal except for the hood and top. Thanks for any opinions given.
AKoldstyle is offline   Reply With Quote
Old 01-03-2010, 09:30 AM   #71
djracer
djracer's Avatar
I would be surprised if you got it that light but I would say 9's if you get it to 3000lbs.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-03-2010, 11:03 AM   #72
69trk
69trk's Avatar
I agree with dj, i would think 3000lbs in a blazer would be very hard to accomplish, it's hard enough to get a truck that light.... i would say in the 9's at 3000 also..
1.58- 60'
11.37- 1/4 @115.81
Old 01-03-2010, 03:59 PM   #73
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
man i wish i could run mine
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-03-2010, 10:59 PM   #74
AKoldstyle
AKoldstyle's Avatar
my blazer is 104 wheel base, and the info i found online about these rigs even with 4x4 and leafs plus 205 tcase and full interior with v8 was said 2 be 3600 lbs. If this is correct i have shed quite a bit of weight and should be very light for full metal body. thanks 4 your guys input.
Old 01-05-2010, 11:49 PM   #75
paul1969
paul1969's Avatar
dont feel bad i thought i done all the good on mine till i rolled the scales at baytown. i cried all the way back to the trailer. it weighed 3525 with me in it. so i say fatman fab a little fiberglass where you can.if that doesnt work then NOS fogger and pill it till you kill it.
69 stepside 489ci
60ft---- 1.46
