09-16-2009, 05:06 PM | #1 |
low n' slo
Pricing for a "z"
Third time's a charm!! Can I get a ballpark figure on someone "z'ing" my frame?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
09-16-2009, 05:55 PM | #2 |
Re: Pricing for a "z"
Are there any shops in your area you can check with? Extensive Kustoms?
09-16-2009, 06:10 PM | #3 |
low n' slo
i could try calling them, but their wait list is always forever and the prices are out of my range!! they do some awesome work though
09-16-2009, 06:27 PM | #4 |
Give Outlaw Motorsports in Fort Worth a call..They do good work..
09-16-2009, 07:00 PM | #5 |
PROJECT 7DEUCE
You get what you pay for don't cheap out on frame modifications..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-16-2009, 07:12 PM | #6 |
low n' slo
i dont plan on cheaping out..theres tons of places im sure that do quality work that is cheaper than extensive, well i hope lol. i read on another forum that some guy would do it for like $300. so i wasnt sure if he was kidding, or if its really that much
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 09-16-2009 at 07:12 PM. |
09-16-2009, 07:32 PM | #7 |
Happy to be here
What might be a more appropriate question is are there any quality shops in your area that can Z your frame.
If your going to Z the front, what are you doing in the rear? Will you need the same shop to build a step notch? I just did a quick search on Google and found the following shops that you might call. Cutten Customs has been around for many years. I don't know anything about Cut Throat Fabrication, but the do show a slammed 68 Burb on their site. http://www.cuttencustoms.com/services.php www.cutthroatcustomsfabrication.com-
09-16-2009, 07:53 PM | #8 | |
It'd be alot cooler if you did
09-16-2009, 08:17 PM | #9 |
67-72 parts collector,…
Make sure you figure all expenses when pricing a "Z". Not just the frame work.
Think about raising the entire engine/trans combo. (as in new engine mounts and trans mounts/crossmember) Raised sheetmetal work for the tranny tunnel and driveshaft tunnel. Custom carpet to use in your now "non original" floor. Custom/modified trans linkage. The list goes on and on. Not being negative,... just want you to weigh all the costs. I had to forget the "Z" idea,... since I can't weld. That's why I chose the Porterbuilt Dropmember route. It worked out the best for me.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-18-2009 at 10:00 AM. |
09-16-2009, 08:21 PM | #10 |
Extensive was charging me $1700 for a Z. This was my first choice but then I ran into this site and the dropmember caught my attention because it was $700 less, nice design, and the steering upgrade. I could probably go on with the benfits but in the long run a DM is the best way to go.
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
09-16-2009, 08:42 PM | #11 | |
09-16-2009, 09:03 PM | #12 |
Wow chuck..Didnt even know about their hack-job till now..
Still..Z"ing the frame dosnt compare to a full-frame build..If they screw that up, Then that would REALLY be something to start a good ol' shop bashing thread about... |
09-16-2009, 09:29 PM | #13 |
low n' slo
lolife, i didnt know all that was involved in z'ing a frame. thats A LOT of work, if all my quotes are anything over 500 then i might has well save up for a dropmember..and it looks like i might lol.
09-16-2009, 09:31 PM | #14 |
Keepin it old school
I was quoted 1,900 for a "Z" by The Choppin Block in Fresno. 1,500 to "Z" the frame and 400 to assemble the suspension..
09-16-2009, 11:02 PM | #15 |
most shops will be between 500 and a grand for the basic Z. Its a ***** if the engine and everything is in the truck.
09-17-2009, 06:13 PM | #16 |
anybody have a pic of a Z'd frame?
09-17-2009, 06:34 PM | #17 |
Happy to be here
09-17-2009, 10:13 PM | #18 |
Thnx n2trux
09-18-2009, 03:56 PM | #19 |
DHPmike that was one of the best replies i have read so far, those guys are realy slick by shaving the bottom of the frame to avoid a body drop.
09-18-2009, 07:21 PM | #20 |
Catchy title goes here..
DHPmike. I apologize, but did have to remove the last two posts due to advertising rules. Please PM me if you have any questions.
