09-16-2009, 12:08 AM | #626 |
I have car A.D.D.
Re: Glock's new project: "Fred"
Dang that is funny!!!!!
Bob, maybe you can just wire mine all up for me? I hate electrical. We can work that in to our trade of services.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
09-16-2009, 12:13 AM | #627 |
Next project: 1970 K10
Consider it done!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
09-16-2009, 12:16 AM | #628 |
I have car A.D.D.
Nice!
09-16-2009, 12:18 AM | #629 |
I have car A.D.D.
That, by the way, is signature material.
09-16-2009, 08:45 AM | #630 |
It's coming along nicely Bob. You'll have that done by the meet for sure.
09-16-2009, 09:04 AM | #631 |
As long as I don't run into any electronic gremlins, I should be good to go!
Oh, and here is the revamped quad light wiring diagram: Relay terminal 30: 12v from battery Relay terminal 85: To ground Relay terminal 86: Signal wire from dimmer switch (low or high beam wire) Relay terminal 87: To headlights
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-16-2009 at 09:06 AM. |
09-16-2009, 10:41 AM | #632 |
aw, what mine wasn't good enough?
j/k
CHEVY ONLY Last edited by joe231; 09-16-2009 at 10:52 AM. |
09-16-2009, 11:43 AM | #633 | |
Still plays with trucks
If there is no room to thread it right in just use one of the common step up adapters that comes with most gauges to get the sender up off the surface and out of the way. |
09-16-2009, 11:47 AM | #634 |
09-16-2009, 11:57 AM | #635 | |||
Lesson learned! This was not one of the things I thought about when doing this swap, the temp gauge sending unit. Next time, I WILL tap the head and install it directly. PS - yes, there is another LS swap in my future.
09-16-2009, 12:23 PM | #636 |
Gas tanks - "OUT FOR DELIVERY"
AN fittings for tranny cooler - "OUT FOR DELIVERY"
09-16-2009, 01:06 PM | #637 |
CHEVY ONLY |
09-16-2009, 02:17 PM | #639 |
09-16-2009, 02:42 PM | #640 |
Saw this on LS1tech.com, it's in a 69, very similar to the 73-87 in this area. Make me a little nervous. Am I wrong?
09-16-2009, 02:47 PM | #641 |
^^^ That's a pretty large chunk of frame missing. Especially since it has gotten so close to the curve (actually looks to be beyond the start of the curve) which would significantly reduce the structural integrity of the frame. I wouldn't do it without some additional bracing in that area. Just my .02
09-16-2009, 02:52 PM | #642 |
My biggest concern with this area is the proximity to the idler arm. It bolts to the frame about 2" away.
09-16-2009, 02:57 PM | #643 |
Formerly- 1972SuperCheyenne
It's coming along nicely. Very nice looking work. Good Job!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-16-2009, 03:13 PM | #644 |
Yeah that would make me nervous too. I would head back to the thinking tank like you are doing for the a/c
09-16-2009, 03:16 PM | #645 |
Wouldn't be an issue with triangulation and some gussets....IMO
CHEVY ONLY |
09-16-2009, 03:26 PM | #646 |
Oh I agree, but the way the fittings shoot up outta there it would be difficult to do that correctly. That is, using the 06's hoses and splice them into the 85's hoses. I wonder though about reinforcing that area by welding some plate around the notch, something heavier than the frame like 3/16" or 1/4" plate on top and on the side?
Now, buying blocks and using 90° threaded fittings would probably allow that area to be raised, boxed on one side, and gusseted.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-16-2009 at 03:28 PM. |
09-16-2009, 04:21 PM | #647 |
I have no doubt you will figure it out while making it even better than it was before. Hhhmmm, remembering a TV show from my youth...could this be the 6 million dollar truck
09-16-2009, 04:31 PM | #648 |
Gentlemen, we can rebuild him. We have the technology. We have the capability to build the world's first bionic truck. Fred will be that truck. We can make him better than he was before. Better, stronger, faster.
09-16-2009, 05:35 PM | #649 |
that should be your sig.
where's the new pics of all the wiring tucked away in looms? i need my fix!! and those last pics look like alot had to be notched out of that frame. it does look like he reinforced it unless im seeing things. just by the way our frame is prone to crack by the steering box i'd be hesitant on cutting that much out. heck i dont even want to notch mine in the rear! another thing is i'm not sure how much pressure that idler arm shaft takes but i'm pretty sure the bolts were only 3/8" but i'll have to double check that... i'm just suprised there isnt a kit or something that adapts to the compressor to point the hoses straight up.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
09-16-2009, 05:45 PM | #650 | |||
There are adapters, but they are worse than the OEM hoses. First there is o-ring the block that mounts to the compressor. THEN the hose fitting screws into that block. So by the time you add those two pieces, the 90° bend doesn't occur for a good 2.5" to 3" away from the compressor. That puts them well beyond the top frame rail. Compressor adapters: And the 90° fittings: You would think someone like Street & Performance should be making a "pancake style" block with threaded fittings coming off the side instead of the top. THAT would solve everything! I'm going to try and fit that thing in there again. I think I can clearance the back side of the bracket enough to make room for the trans cooler lines. I gotta make this work! I know I can! I wish I had a spare frame and a block to play with........
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-16-2009 at 05:51 PM. |
