Old 09-18-2009, 10:26 PM   #1
superchevy
Got big-block?
superchevy's Avatar
some build pics of the GMC K25
Started about a year and a half ago. Bought it as an unfinished project for a bodyshop I call on. Already had a 454/700r swapped in...that had to go and a 468/4L80e put in it's place. Here's a few pics of the progress:
Pic 1 is as bought
Pic 2 is of the 1990 454 that was in it
Pic 3 is of the 454/700r pulled
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 09-18-2009, 10:28 PM   #2
superchevy
Got big-block?
superchevy's Avatar
Re: some build pics of the GMC K25
Got the cab and bed off the frame. Installed the front engine crossmember. Cleaned and painted frame.
build thread
build thread
Old 09-18-2009, 10:31 PM   #3
superchevy
Got big-block?
superchevy's Avatar
pics
build thread
build thread
Old 09-18-2009, 10:35 PM   #4
superchevy
Got big-block?
superchevy's Avatar
Mounted the gas tank in the rear and cut out a small pocket in the rear of the bed to put in a stainless boat fill.
build thread
build thread
Old 09-18-2009, 10:42 PM   #5
superchevy
Got big-block?
superchevy's Avatar
Rebuilt the front and rear axles and suspension...warn hubs...tough country 4" front suspension lift...ORD rear shackle flip kit for 4" lift...2" body lift...custom rear sway bar...
build thread
build thread
Old 09-18-2009, 10:45 PM   #6
superchevy
Got big-block?
superchevy's Avatar
rear susp
build thread
build thread
Old 09-18-2009, 10:47 PM   #7
superchevy
Got big-block?
superchevy's Avatar
Got the drivetrain mocked up, built and installed...468/4L80e/np205...all fresh and completely rebuilt
build thread
build thread
Old 09-18-2009, 10:51 PM   #8
superchevy
Got big-block?
superchevy's Avatar
pics
build thread
build thread
Old 09-18-2009, 11:10 PM   #9
superchevy
Got big-block?
superchevy's Avatar
Just last week got all the shhetmetal finished and cut in...now to hang the doors, frontclip and get it finish painted...then all the little things to hook up...
build thread
build thread
Old 09-18-2009, 11:15 PM   #10
highperf4x4
Awesome!
You gonna share what customizations it took to get them chevelle manifolds in there?
highperf4x4 is offline   Reply With Quote
Old 09-18-2009, 11:28 PM   #11
superchevy
Got big-block?
superchevy's Avatar
Lol...had to cut and box the frame.
build thread
build thread
Old 09-19-2009, 12:15 AM   #12
highperf4x4
SEE!!!!! That's the kind of info you have to share!
Are you SURE you got that fram stiffened up enough? It is a 4x4. Are you gonna punish it?
Old 09-19-2009, 05:38 AM   #13
If I may answer for Superchevy,"no" .i think i recall when you bought this your intentions were for a tow/hauler.that pretty black paint,Heavier o/d,and swap bar seem to point in that direction.BTW...NICE!!!!
Now,the secret I want you to share is how you`re handling the speedo drive?Are you going with an electronic to mechanical converter or an electronic speedo?Was the trans from a 6.2 diesel with stand alone ECM,did you have to buy an aftermarket`puter,or go manual kit?Here`s a little coinky dink,I have a`72 K2500 and a 4L80E I`d like to use in it.Don`t worry,I won`t paint it black.
Old 09-19-2009, 09:20 AM   #14
superchevy
Got big-block?
superchevy's Avatar
special-K is right...I built it to tow my trailers and cruise around in. As for the 4l80, it's out of a 96' dually...I bought the TCI stand alone computer/harness to control it. I used a T400/np205 adapter...had to have it turned down by a local machine shop to mate to the 4L80...had to change the output shaft as well...
build thread
build thread
Old 09-19-2009, 11:43 AM   #15
superchevy
Got big-block?
superchevy's Avatar
special-k, back when I was researching the 4L80 swap details, I ran across a couple of posts (can't remember where) that the 4L80 has a speed sensor port in the case....if I remember right...it might have two...maybe it was only some 4L80's...anyway...when I got the TCI harness...the instructions showed how to plug everything in, and the location for the speed sensor. I got the TCI tps harness as well to mount to the quadrajet base plate.
I can't remember if I could use the transfer case speedo outlet or not...I'll have to dig out all the freakin' info/manuals when I get ready to dial everything in...I'm sure there's something else I need to buy, lol.
There's a lot to figure out on this swap, and it is very expensive...I have more in the trans/rebuild/converter/computer than I paid for the truck originally...a lot more...if I had to do it again, I would seriously consider a T400/gearvendors o/d set-up
SC
build thread
build thread
Old 09-22-2009, 11:08 PM   #16
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looks like its gunna be a cool truck man! Maybe i'll see it some day, your not very far from me.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-13-2011, 06:07 AM   #17
coggonobrien
i know this thread is a little old but as for the rear shackle mount you have, how much lift did that gain you. also any pics of the finished product?
coggonobrien is offline   Reply With Quote
Old 01-13-2011, 10:00 AM   #18
superchevy
Got big-block?
superchevy's Avatar
That's a 4" rear shackle flip from ORD.
I'm finishing up final assembly of the truck right now.
Need to update my build thread...you can find it in my sig.
Casey
build thread
build thread
